Results 41 to 50 of 55
- Aug 2009
- 35
September 13th, 2009 02:55 AM #41I forgot the brand name, pero iisa lang yun
brand from CitiMotors Mitsubishi, Pasong Tamo,
in front of Don Bosco, Makati. Ask for their
Mitsubishi Fuel System Cleaner - about Php400 each.
I purchased two bottles of it (naka pale green packaging) ito.
Drove at Shell Gas Station, poured one bottle sa fuel tank baka
ako nagpa-full tank. I felt improvement agad in the idling!
I decided to use the car almost everyday para maubos yung
gasoline sa fuel tank ng car.
After almost 2 weeks, when the fuel gauge showed 1/4 na lang
ang natitira sa fuel tank, I poured the contents of the 2nd bottle
in the fuel tank - tapos pafull-tank uli.
I believe na nawala yung nginig because of two things:
1st - dahil sa paggamit ng Fuel System Cleaner;
2nd - pag correct ng timing ng car
My mechanic was the one who adjusted the timing of the car.
The timing was initially in the "0" (zero) position!
Looking at the sticker pasted under the hood, dapat nasa "10" ito.
Inadjust ito ng mechanic using the distributor.
There were two mechanics who adjusted it - yung isa hawak-hawak
yung timing light sa left portion of the car, while the other one
adjusted the distributor.
Margaret
P.S.
Just curious, where in Alabang did you get the throttle body cleaned?
- May 2008
- 50
September 13th, 2009 07:30 PM #42
- Aug 2009
- 35
September 14th, 2009 01:27 PM #43
September 23rd, 2009 05:52 PM #44
Greetings Tsikoteers...
Swak na swak para sakin itong thread na ito, because my cars seems undergoing the same problem right now. Mine is a 96 Gli Corolla na madalas ngayong makaranas ng nginig specially when AC is on. Pabago-bago din yun idling and seems humihina na hatak nya. Actually kakapadiagnos ko palang sa Casa last week and ang mga pinoint sakin were the Engine Support, Pull Down and Checking of Throttle Body and problem with Clutch daw. Though di ko muna pinagawa because medyo mabigat yung quotation. Now, I'm planning na i by part muna ang pagawa and unahin yung cleaning ng TB. Me mairerekomenda ba kayong bihasa sa pag gawa nito bukod sa casa? I'm from QC.
Also, question lang dun sa Mitsubishi Fuel System Cleaner. As in ihahalo lang ito sa gasolina?(sensya na po, di ko nabasa yung actual thread nito e). Occasional lang po ba pag gamit nito o every pagasolina? How many times po ba dapat gawin?
TIA
- Sep 2009
- 1
September 29th, 2009 08:49 AM #45Mukang ganito talaga sakit ng toyota gli kasi halos ganito din problema ko sa kotse ko 1993 model. Kapag naka idle ako at nag turn on yung aircon biglang bumabagsak yung rpm ko na parang mamamatay na yung engine. Kapag tumatakbo naman ako randam na ramdam ko yung pag on/off ng aircon kasi medyo nahihirapan yung andar nya at pati yung headlight ko napapansin ko lumalabo kapag nag on ang aircon. Sana po matulungan nyo kami kasi napa check ko na sa servitek wala naman pinagbago aganun pa din
- May 2008
- 50
November 25th, 2009 04:17 PM #46Update on my Corolla GLi 95.
I consumed 1 prestone fuel injection cleaner additive and 2 mitsubishi fuel injection cleaner additive. Still vibrating.
I had my servo cleaned last weekend (very dirty). Still vibrating.
The problem is, when the compressor runs, the rpm goes low instead of rising, that causes the vibration. During idling * 1000 rpm without aircon, the engine is smooth. When compressor runs, the rpm goes down (from 800 rpm to 950 rpm) which results to vibration. There are times that the rpm rises to 1200, in this rpm, the engine is smooth.
I will post the result after I tried another solution to this problem.
Happy motoring.
- Mar 2004
- 652
January 31st, 2010 03:33 AM #47sir,
di ko sure kung dito ko na i post noon. but your problem with your gli is identical to my 93 gli two years ago. sa kakalikot ko, i noticed that the idle up valve is not acting as it should be.
Note: when the engine is in normal idle rpm (800 to 900) with the air con off, the engine is running smooth. pag nag engaged ang clutch sa air con dahil nag demand na ng cooling, additional load iyan ng makina kaya pag hindi compensated, mag vibrate iyan o manginig na parang mamatay dahil bagsak ang rpm to about 600. ang trabaho ng idle up valve is to by pass air to the intake manifold to compensate for this additional load, thus increasing the engine speed to 1000 rpm. tingnan mo kung original pa ang idle up valve niyan, meron iyan adjustment to increase or decrease the air intake o baka talagang malfunctioning na ang valve na iyan. that'sthe valve na naka kabit sa fire wall, just above the throttle body, with two tubes connected, one is goind to the throttle body, the other is going down somewhere on the engine.
hope this helps.
- May 2008
- 50
February 5th, 2010 08:56 AM #48
- Oct 2008
- 15
- Oct 2009
- 19
February 18th, 2010 08:14 PM #50100% compressor ang problema mo, palitan mo na ng bago huwag ng surplus. medyo me kamahalan lang pero sure ka naman na mawawala yang problema mo. sparkplug din pacheck up mo.
