Page 49 of 50 FirstFirst ... 39454647484950 LastLast
Results 481 to 490 of 500
    Feb 2019
    #481
    Hi! I'm new here! If I may ask, last month my clutch is already slipping, so I had it replaced. I also experienced yung nanginginig ng malakas sa biting point ng clutch, so I had my clutch set replaced na. So ang nangyari po, gumanda na hatak niya, normal na, pero yung panginginig ay nandon parin. I was suspecting engine mounts kasi may cracks na sila sa rubber part. My question is, are busted engine mounts the ones that are causing the drag or panginginig sa biting point ng clutch ko?
    Naeexperience ko lang po ito sa primera, and minsan sa segunda kapag dumirecho ako dun kahit medyo mababa rpm and takbo ko.
    TIA guys and will be looking forward to your answers.
    Sep 2018
    #482
    11.3 to 11.6 km/l mixed city/hiway(80/20).. matic 4afe, what d u think?
    Sent from my SM-A710F using Tapatalk
    Sep 2018
    #483
    I heard from a mechanic that by using additional grounding cable from battery to starter will help eliminate the hard to start after a long drive. Lumakas din daw hatak..
    Anyone has information on this?
    #484
    Quote Originally Posted by reymund View Post
    ...hard starting after a long drive?... remedied by extra ground wires?
    ..sounds like loose grounding to me.
    perhaps if we tighten the grounding bolts first...
    Sep 2018
    #485
    Naexperience ko yan doc nung pinatay ko makina then pinalipat kami kasi bawal magpark dun sa pinwetuhan ko,wala pang 30 seconds, hindi na sya ngstart, have to wait a minute din ata yun before ng start ulit. As per mechanic na nakausap ko, naexperience narin daw nya un with new battery, so he tried putting extra grounding wires nga.
    #486
    does your starter revolve the crankshaft, but ignition does not take over? if so, it would appear, you have an intermittent. it might be difficult to zero in on the culprit, as it's an... "intermittent".
    or does your starter not move at all? in which case, i think it's just your starter solenoid that needs fixin' or replacement. this is easy to troubleshoot. the knowledgeable mechanic can do it with a screwdriver. if it is the culprit, just have it replaced, po. the starter solenoid, i mean.
    good luck.
    Sep 2018
    #487
    If i remember it right, no movement. Could it be battery?
    #488
    i don't think so.
    a weak battery can probably still do some engine movement, even if only a bit.
    a dead battery wouldn't make any movement, even if one waited an hour.
    i think it's your solenoid.
    errr... the big one piggy-backed to the starter, not the cute black cube thingees in the engine bay.
    Sep 2018
    #489
    Could be.. but this rarely happened. Thanks, doc.
    Sep 2018
    #490
    May pinapalitan bang something dun sa door area kung halimbawang yung tunog pag sinara pinto parng hindi na sya kagaya nung bago bago pa? Napansin ko mejo iba na tunog lately..
Toyota Corolla AE101 Owners & Discussions [Merged]
