Results 461 to 470 of 500
- Jul 2016
- 5
July 22nd, 2016 10:45 AM #461
- Jul 2016
- 5
- Jul 2016
- 5
July 22nd, 2016 10:48 AM #463
- Jul 2016
- 5
- Jul 2016
- 4
- Jul 2016
- 3
- Jun 2016
- 32
July 31st, 2016 02:13 PM #467ano pong recomended nyo na engine oil, spark plug para sa 2e engine corolla?
- 54,271
July 31st, 2016 08:21 PM #468
- Aug 2013
- 475
August 2nd, 2016 10:29 AM #469
- Aug 2016
- 33
September 13th, 2016 05:29 PM #470Hello peeps!
Please bear with me, this is quite a long one.
My corolla 2E had these symptoms:
-overheating
-engine dies when you lift your foot off the gas pedal
-blue smoke from exhaust
-sludge forming on the radiator cap
-loss of coolant
-extreme loss of engine oil
I brought it to my "trusted mechanic" for a top overhaul and he fixed some things including:
-thermostat
-timing belt
-replaced valve seals
-oil and filter (of course)
-piston ring (nakita niya putol)
-gasket
-spark plugs
overall cost: 14K
After getting the car back, I immediately did:
-radiator overhaul (badly needed)
-replaced the non working radiator fan
overall cost: 3K
So I was happy coz I thought everything should be fixed by now (spent 16k on that alone). After driving it gingerly for a week in manila, these problems started showing up:
-MASSIVE blue smoke from the exhaust (mas malala pa to kaysa bago ko ipa-overhaul
-VISIBLE smoke from the engine bay, pag tinanggal mo yung dipstick, sobrang daming usok galing sa loob ng engine
-idle came down to 200
-erratic revs when AC is on, biglang tataas to 2k then babagsak to 300. Mga 5 times na ganon before returning to normal rev
-after 3 days, massive vibration. Engine will die when I turn the AC on
-after just a week, noticed that the oil level has gone down
I decided to bring it back to my "trusted mechanic", he said I should have the carb checked. He referred me to another mechanic who specializes in carb:
-had the carb checked and cleaned
-checked the camshaft
-mechanic saw that one of my newly replaced spark plugged was already shot so he replaced it (2 weeks and the damn thing already destroyed a spark plug)
overall cost: 1.8K
After all these, the car still have:
-Massive blue smoke from the exhaust and from the engine bay
So having determined that the carb was not the problem, I brought it back to my "trusted mechanic" and he told me that the engine needs to undergo rebore. Damn. After spending almost 18K, he now tells me it needs a full overhauling. I saw a post from here that an engine overhaul costs somewhere between 25 to 30k. Nawalan na ko ng tiwala sa mekaniko ko after nito. Kung iisipin ko, gumastos ako ng 18k at para lang mawala yung overheating issue. Nakaklaungkot. Any advice, guys? Thanks in advance.Last edited by iceman007; September 13th, 2016 at 05:38 PM. Reason: additional details
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
