Results 451 to 460 of 500
- Jan 2015
- 26
November 16th, 2015 04:39 PM #451hi mga sir! a newbie question about timing belt replacement.
upon researching meron pa lang timing belt kit and ito iyong mga items na kasama:
1 ArmorMark Timing Belt (117 teeth)
1 GMB Roller Tensioner Bearing
2 Camshaft Seal (35 x 49 x 6)
1 Front Crankshaft Seal (32 x 46 x 6)
1 GMB Water Pump with Gasket
1 Valve Cover Gasket
4 Spark Plug Tube Seals
4 Grommets
ito na po ba lahat ng dapat palitan kapag magpapalit ng timing belt? meron po ba nito sa Pilipinas na genuine toyota brand lahat, if ever saan po makakabili? how much po ang total ng magagastos from parts to labor?
*kakapalit ko lang ng valve cover at grommets, yung spark plug tube seals pinapapalitan na sa akin ng mekaniko nung nagpapalit nga ako ng valve cover.
thanks in advance
- Aug 2013
- 475
November 16th, 2015 05:49 PM #452pwede ka naman bro bumili ng timing belt, tensioner, camshaft oil seal, at crankshaft oil seal lang ang palitan mo kung bago pa yung iba.
pwede bumili sa casa ng mga yan.
pwede mo din icheck yung mga fan belt kung palitin na.
timing belt = P1.5k to P1.8K OEM
oil seals (camshaft at crankshaft) = P250 to P450 OEM
labor fee = P1.5k to P1.8K
sa tensioner hindi ko na matandaan.
- Jan 2015
- 26
November 17th, 2015 01:45 PM #453maraming salamat sir!
- Mar 2016
- 8
March 31st, 2016 09:59 PM #454tanong lang, meron akong toyota corolla lovelife. Kaka lowered lang with maxspeed tapos kyb gas type shocks. Problema ko is kahit tatlong pasahero lang meron ko sumasayad na kaagad yung gulong ko sa fender. Any advice without changing the mags and tires (17" 205/50)?
- Jun 2016
- 1
- Jul 2016
- 3
July 20th, 2016 03:51 PM #456Good day magser/ma'am newbie here,
I'm planning to buy a Toyota Corolla Gli
I was just wondering kung magkano na ngayon ang value niya
This will be my first car if ever, nagbasa basa na rin po ako about it
at maraming nagsasabi ng positive about the Corolla Gli
Salamat sir/ma'am for advance
- 54,271
July 21st, 2016 01:45 AM #457gloss over the car sellers' ads, po, to give you an idea of the range of prices.
try olx.
but go see the cars in the flesh. only then can you see if the car is really good or truly bad, and (hopefully) you will see how condition reflects price.
one thing i can say about old cars... the older the car, the higher the chance of something needing fixing up. yes yes... there are exceptions. and that exception is what we want to buy.
lastly, when you buy an older car, be aware that even if you restore it to factory spec, it might still feel like an older car. that is because your efforts are limited by the technology when that car was first built.
for example, a factory spec gli might (heaven forbid!) not be as nice to drive as a poorly maintained altis. (hey guys, example lang! don't get mad...)
good luck.Last edited by dr. d; July 21st, 2016 at 02:05 AM.
- Jul 2016
- 3
July 21st, 2016 04:18 PM #458
Thank you sir dr. d, may nakikita po ako about around 100k ~ 150k thru online
yung budget ko mga sir/ma'am is around 120k, sakto na po ba ito for a good condition and good for long run?
sa mga nabasa ko din po kasi Gli, almost the same sa XE in fuel consumption
ang plan ko pagmeron na ako natipuhan kotse I'll bring some of my friends and mekaniko to also check the car
syempre pagOk na lahat, I'll have it full check up (double check lang po dahil this would be my first car nga po..just to make sure all are good at kung my papaltan mapapaltan na po)
- 54,271
July 21st, 2016 11:51 PM #459it is always prudent to have some money left over, for fixin's. 20K, siguro.
a car that old and that cheap, can not be in pristine condition. there will surely be something you will notice the first week, that you want fixed, if only for safety's sake.
next year na yung for beauty's sake.
and, oh! buy the most expensive you can afford. these usually offer less repair problems, than the cheaper ones.
as the benz aficionado said, "the most expensive MB is the cheap one".
- Jul 2016
- 5
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
