Results 431 to 440 of 500
- Dec 2006
- 27
October 6th, 2014 09:49 AM #431sir tinanggal ko yung fender liner at inangat ko yung carpet sa driver side, sa fender liner maayos po yung goma na nilusutan ng mga wire papasok at wala sign ng pumasok na tubig, ang nakita ko basa pa yung may takip na parang goma na carpet sa ilalim ng pedal, ung naka ipit sa mga screw ng hydrovac, di ko na alam kung panu pa tanggalin, san kaya lumulusot ang tubig???
- Jun 2012
- 12
October 13th, 2014 08:33 PM #432mga bossing... patulong naman... for toyota corolla gli ae101
-nasira po ang alternator ko, sabi ng mechanic IC dw problem, same po ba ang IC ng xe sa gli? meron kasi available IC from xe model, just wondering if pwede gamitin... adviceable bang bumili ng replacement IC (circuit brand, etc) or surplus na lng?
-also, hindi po umiilaw ang oil and battery indicator ko sa gauge panel, tested ok naman po ang guage panel including the bulbs... ano po kaya ang sira? meron ba sender ang battery and oil?
thanks for the help sirs!
October 17th, 2014 11:09 AM #433
Sir dalhin mo na lang actual yung alternator mo, need mo icheck ang plug at mga bracket kung pareho. Para makita kung maimount and maiplug. Iba iba kasi sukat lalo na ang plug, 2 days ago I bought an alternator for a 3s engine mounted on my big body, ang nakuha kong alternator is for Corona.
October 17th, 2014 12:11 PM #434
kuha ka nalang replacement,
gamble ang surplus, it may last again for 3-4 years,
or pag minalas 3-4 weeks, had the same
problem before back then, when i still own my GLi,
ignition coil ang pinalitan, i opted for a replacement
brand, forgot the brand, hindi sya circuit, meron pa isa,
and that ignition coil lasted up until binenta ko na yung kotse,
forgot the price nadin pero hindi sya 3.5k,
it is way cheaper than that.
- Jun 2012
- 12
October 18th, 2014 06:48 PM #435
- Jun 2012
- 12
October 18th, 2014 06:50 PM #436meron na po ba nakapagpa wire-tucking? yun tatago mga wires, minimal wires lang visible sa engine bay...
around how much po ang labor nun? how much din po kaya ang aabutin ng materials? para makapag budget lang. thanks!
- Oct 2014
- 3
October 20th, 2014 05:37 PM #437hi...
good day forum peeps....
am so new at this, so can anyone help me find or teach me where to look for parts, kits and the like, to improve my current corolla 2000 car set-up.
thanks so much...
- Jul 2011
- 11
October 24th, 2014 08:35 AM #438Mga nasa 900 lang yata kapag yung Ignition Coil Lang try search 2e ignition coil sa *******
2e Corolla Ignition Coil - Brand New For Sale Philippines - 58261179
Buong distributor na surplus na siguro yung 3500
- Mar 2015
- 8
March 25th, 2015 02:47 AM #439Hi Mga Sirs! Need help on my Corolla po, Spark plug gets wet by the oil palagi, madami nagsasabi po na overhaul na, Top overhaul sabi nung iba, ang problema, wala ko alam sa kotse masyado po.. Need advise mga sirs! Thanks po!
- May 2015
- 2
June 11th, 2015 02:47 PM #440Gud day mga papa! Newbie lang po ako sa pag sasasakyan.
Ask ko lang kc ung aircon ko bagong linis at karga ng freon bagong palit nadin ang drier At expansion valve pero halos d padin mo ma attain ung lamig kapag tanghali pero sa gabi or hapon ok naman sya actualy may nag momoist pa ung windshield ko gabi. Anu po kaya problema ng aircon ko mga paps? TIA!
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
