Results 351 to 360 of 500
August 27th, 2012 07:58 AM #351
August 27th, 2012 09:20 AM #352
psilens: if you have the budget, since you're after additional performance din naman, change your engine. If you want something economical get 4EFTE. FC stays around 9-12km/L on the city UNLESS you start spooling the turbo.
It's a 1.3L Turbo. And rated, if I'm not mistaken, around 130hp stock.
You'd spend around 60k to complete the swap. Power is evident on low-mid range.
Kung parati ka naman highway at duluhan na power ang gusto mo, there's the 4AGE ST. It's a 1.6L 20V NA engine. Rated at 158hp stock. Not quite economical but the power is addicting (remember initial d? hehe) around 7-9km/L in the city if tuned properly. You'd spend around 50k for the swap.
Then there's his bigger brother, the 4AGE BT. 163hp stock. 6-speed MT.
Hth.
- Apr 2007
- 9
August 27th, 2012 02:16 PM #353And so begins my journey under the hood hehehe. Thanks for the input renzo and 7138
I'll read up on the 4efte.
Any recommendation on good trustworthy shops? Or can I go with speedlab?
August 29th, 2012 08:17 PM #354
HP Racing is one. They specialize on turbochargers so swapping your engine should be a no biggie for them, besides, Al owns a Corolla with a 4EFTE as well.
SB Salon is another good place to go to. He's highly recommended by GrupoToyota (you might want to check their forum..) peeps. The shop is somewhere in Cavite, Shaggy can do everything Toyota. From swapping your 4AFE to 3SGE, 4AGE, 5AFE, 7AFE, 2NZFE etc.
- Sep 2012
- 3
September 4th, 2012 04:53 PM #355
September 4th, 2012 05:52 PM #356
- Sep 2012
- 3
September 4th, 2012 06:41 PM #357
- Apr 2007
- 9
September 7th, 2012 10:33 PM #359
[IMG]
[/IMG]
Mga sir patulong naman baka may nakaka alam ng diagram na ito malabo na kasi di ko na mabasa. maraming salamat!
September 8th, 2012 09:45 PM #360
here it is...for toyota corolla AE101/EE100 -- 2e and 4afe, fuse diagram in engine compartment
btw, yung fuse no.13, that is the fuse of Dome/Interior Light, Trunk Light, Open Door Warning Light, Clock, and Stereo.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
