Results 341 to 350 of 500
- Jul 2004
- 59
June 17th, 2012 10:27 PM #341Mga sir me balak po ako bilhin na gli 94 at kaso newly overhauled at fade na paint e ano po ba dapat ko check para malaman kung me tama pa ang engine? Lo budget lang po kasi kaya pinag iisipan ko pa po. Tnx
August 9th, 2012 05:46 PM #343
Walang XL na 1.6.
Yung Corolla na binenta from 1997-2001 (pero nag-extend til 2005 for the XL) ay AE111. Ganito itsura:
XL - 1.3L 2E engine (72 HP, carbureted), manual windows/door locks/steering, steel rims, black bumpers/side mirrors/door handles
XE - 1.3L 2E engine, manual windows/door locks, power steering, alloy rims, body-colored bumpers/door handles
1.6 GLi - 1.6L 4A-FE engine (110 HP, EFI), power everything, airbags, ABS/EBD
1.8 SE.G Altis - 1.8L 7A-FE engine (120 HP, EFI), all the features of the GLi + leather seats, 6 speakersLast edited by jut703; August 9th, 2012 at 05:51 PM.
August 9th, 2012 06:31 PM #344
August 26th, 2012 01:53 PM #345
Last Friday pag start ko nung umaga palyado yung makina nung 1995 corolla xe 2e, So check ko yung spark plug maitim na so pinalitan ko pati yung air filter.
Kaso hindi pa rin tumino yung takbo, ano kaya yung problema? High tension wires ba or yung distributor assembly?
- Apr 2007
- 9
August 26th, 2012 11:30 PM #346may magagawa ba sa 1.6L '94 corolla to make it more fuel efficient? i want to have our '94 corolla fixed up instead of buying a brand new car. Fix up the engine setup, under chassis, etc etc.
August 26th, 2012 11:35 PM #347
August 27th, 2012 12:21 AM #348
As stated, ano sir current fc mo?
Pa compression test mo muna sir,
If pasado pa....
- tune up
- change oil, use lighter oil, kahit 15w40, instead of 20w50
- change air and fuel filter
- pa check/adjust mo na ang wheel alignment and camber
- palinis throttle body
- linis ng auto, mga kalat sa trunk adds weight,
- pa adjust mo sa tamang timing
Yan, definitely aayos fc mo nyan.
But if kahit may isang bagsak sa kanilang apat..
Your choice if pa-top/general overhaul mo engine mo or,
As stated, engine swap.
Your choice.
Goodluck!
- Apr 2007
- 9
August 27th, 2012 01:46 AM #349Exact FC maybe something like 6-8km/l city driving. We spend around 4k-6k on gas per month.
I want to bring the performance of the car up, unfortunately wala ako masyado alam pagdating sa kotse. So far i've searched for under chassis specialists and also considering speedlab pero no clue what i should even be considering.
Meron din problem yung engine or assembly (or whatever it's called) kasi pag rev then nag release ka ng clutch (even slowly) the car goes into a violent convulsion (haha violent talaga)
thanks for the help!
Also, meron bang recommended shops in terms of quality of work and trustworthiness? I've been looking pero having a hard time looking for feedback. Halos bagong kotse na kasi ngayon. I don't think I can deal with too many shops for the multiple things that may need fixing.
Big thanks ulit
August 27th, 2012 07:56 AM #350
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
