Results 331 to 340 of 500
- May 2012
- 6
May 30th, 2012 05:45 PM #332
hi mga sirs. Wanted to ask if yung stock struts ng 101 were fluid type? palitan ko sana saken and type ko yung as close to stock as possible yung ride nya.
- Jun 2012
- 12
June 1st, 2012 03:30 PM #333Hello...
Toyota Big Body owner. 1993 XE... useful lahat ng mga posts nyo. Thanks!
Just want to ask kung ano ang mas ok ilagay na lowering springs: Tien H-tech or Tien S-tech...
also, ok na ba ang KYB ExcelG na struts para sa Tien lowering springs?
THanks in advance
June 6th, 2012 12:32 PM #334
mga paps ano kaya nagyari sa big body ko gli matic ko biglang umusok ng puti tapos parang may singaw sa engine sa may manifold busted kaya ang cylinder head gasket ko? di naman humalo ang langis sa tubig thanks in advance
June 11th, 2012 02:23 PM #335
Help! Ihave a 98 gli 4afe bigbody,what happen was iwas driving nang biglang nag check engne then nagloko gauge ko rpm naglako eratic pumipitik hangang 8-9000rpm kaht idle o kaht naka on ignition ko. Then pinatay ko 5min then start normal lahat hangang nauwi kopa sa bahay. The next day pag on then start nagloko uli rpm umi ikot ikot dinala ko evanglsta sunog daw idle valve o servo daw, then pinalitan eto hindi ma balance ang idle at pag on ang ac, mataas ang idle hangang 1,5k pag off ac 1k, or the way around, hirap silang timplahin, kaht na adjust na distrbutor. Sabi servo papalitan daw nagloloko pa kasi nalinis na throttle at napalitan na buong set servo pa din daw. San ba ok magpagawa sa banawe? Any contact? Servo pa tlga? Nakapag change oil nako, but not spark plugs and air filter ok pa naman daw. Sabi din grounded kasi nagloloko rpm gauge.
- 48
June 12th, 2012 02:59 PM #336try to install a known good working ecu first to isolate the problem... imho
- Jun 2012
- 12
June 13th, 2012 04:46 PM #337
June 13th, 2012 05:03 PM #338
June 14th, 2012 09:03 AM #339
June 14th, 2012 12:15 PM #340
nakow di nga basta basta advance ng dist. usually 10 deg btdc dun sa sticker sa hood. dalhin mo na nga sa mas marunong at pang carb yung moves nung unang gumawa.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
