Page 29 of 50 FirstFirst ... 1925262728293031323339 ... LastLast
Results 281 to 290 of 500
    Mar 2004
    #281
    Quote Originally Posted by power eagle View Post
    FC city between 8-9km/L
    hway approx between 12-14km/L MAX 5PAX wd hataw from manila to marine base. Gas up for 600 using petron xcs. Btw i use xcs or xtreme97 fuel. All stock unit fastest i hit was 180km/h at 5,xxx rpm kaya pa e me nginig lang sa manibela na curious lang ako kung hangang saan ang kaya
    2. Same idle settings
    3. M0bil 1 oil gamit ko
    you're lucky to have such a high FC. On my case, sa tingin ko di na=break in ng husto ang gli ko kaya mababa ang FC. On speeds naman, I have tested it sa Macapagal hi-way ( nung medyo bago pa ito at kokonti pa lang ang dumada-an), raced up with a bimmer, reached speed of 180 at parang humihingi pa ng isang kambyo ang makina (btw, naka on pa ang aircon nito, nakalimutan ko i-switch off). I felt na kung isagad ko ang silinyador, may ibibigay pa ang makina. the problem is, hindi na kaya isagad ng dibdib ko he-he-he.
    Nasubukan ko na rin ito sa honda civic, from Roxas, Mindoro Oriental, malapit na sa Calapn ng maka overtake siya as I have to slow down at hinahanap ko ang turn-off patungo sa pier.
    Kaya kuntento na ako sa oto na ito, it's engine is not a performance engine, 4AFE, but it could give you speed when needed. Just I was thinking, what more kun nasalpakan ito ng 4AGE engine? One time I was cruising along NLEX at 160, when just passing the viaduct separating Bulacan and Pampanga, a small body corolla gl whizzed by past me as if I am standing still. I told my wife, Ah, mebbe it's engine is already souped up nya=h=ha.
    #282
    nice experience with your corolla sir, na appreciate ko yung pagkatipid niya when i had it change oil and replace air fuel filters ang spark plugs. Yup 4afe is n0t for drag racing pero pagkailangan mo just step on thegas dika bibitin just know your engine powerband. Light body di nakakapagod drive pag long driving at marami parts kahit tabi2 mura pa dimu kelangan dumayo mag hanap ng pyesa. Next inline ko aircon cleaning although malamig cya naninigugrado lang hehe. Problem lamg pag gabi nag moist sa windshield lumulusot yung a/c sa vent windshield e
    Jul 2011
    #283
    ako, 6-7 km/liter padin, madiin lang paa ko i think. puro looban pa, kaya stop and go.
    nagpadagdag pa sa fc ung ginagawa sa araneta. tiis nalang talaga.
    ^^^ ganyan din ae101 ko sir, nagmomoist sa windshield, lalo na nung walang tints, garapal yung moist, pinupuno yung bottom part ng windshield, nung nagkatints, hindi na gaano, matagal tagal bago ulit sila lumilitaw, pero kokonti nalang.
    #284
    sakin kaht my tints moist pa din lalu pag pa gabi na at malamig na buong windshield my moist kaya wiper ako ng wiper. Now problem ko pag di nagagamit oto pag weekdays pag weekend my times hirap start na didiskarga. Dunno kung battery starter o alternator pero sabi prev owner mahina na daw battery when i had it check ok pa naman daw puwede pa. Pag istart mo wlang power minsan diskargado. Pero nung pina charge at nagstart ok na, kumakarga naman. Pag na teng ga uli ganun uli. Hmm baka yung alternator pa check ko pag me time.
    Jan 2009
    #285
    Hello po mga boss. Newbie lang po ko dito. I drive 95 xl, mga 6mos pa lang sakin. Satisfied naman ako overall, meron lang 1 minor 'problem'. Tanong ko lang po if normal lang yung pumapasok yung amoy sa labas esp. pag naka-ac? Not sure why, pero ok pa naman yung mga weatherstrip wala naman natanggal. Possible po kayang yung sa may ac filter (not sure kung yun nga yung tawag)? Help naman po, I need your expert advice. Thanks in advance!
    Mar 2004
    #286
    Quote Originally Posted by PonkyMan View Post
    Now, pag napapansin mo na pumapasok ang amoy mula sa labas, that means to say that naka bukas ang air vent mo or meron leak. Komo 2nd hand mo nakuha yang oto mo, di mo alam kung ano ang kinalikot dyan from its previous owner. better, kung me kilala ka na marunong mag butingting, pa check mo kung okey ang fresh air vent ng oto mo. isa pang maaring daanan ng amoy mula labas ay ang pinagtagusan ng tubo ng air con. buksan mo ang hood at tingnan kung ang rubber grommet na nakabalot sa tubo ay OK pa. ang tubo ng air con is the aluminum tubing, isang malaki at isang maliit, usually nasa right side ng firewall.
    Jan 2009
    #287
    Quote Originally Posted by burjegol View Post
    Ayun AC vent nga siguro. May tinakpan na dati 'yung mechanic ko don baka lang natanggal. Pasisilip ko na lang sa kanya this Sunday. Thanks sir for the prompt response!
    Jan 2009
    #288
    Mga boss, tanong ko lang po if may tire fitment guide kayo ng pang big body? Plano ko po kasi sana magpalit ng 16s, di lang ako sure kung pwede 205/50 na goma. 'Yung usual ko po kasing nakikita is 195/50 pag sa 16s. Thanks!
    #289
    Mura lang naman magpapalit ng 4AGE ST/BT, eh.
    50k with wirings.
    Mahal yung 4EFTE 1.3L Turbo. Huli kong pa-quote is 70k everything.
    Never ko pa na-try mag-high speed run, huli kong hatawan is 150kph. Puro hard acceleration ang usually ko nagagawa, just this Saturday binanat ko at 2nd gear yung akin. 65kph. 1.3L
    Jul 2011
    #290
    Installed grounding kits knina sa banawe in my 101, i dont think placebo, but nung unang arangkada plang, with aircon on, lumakas hatak nya, sinilip ko nga ung ac switch ko just to be sure, nka on ung indicator, kala ko headlight lang magbebenefit, doubt pa ako sa una kung maaapektuhan din ang overall performance ng engine, not very great ang difference pero noticable naman na lumakas. For an 800 pesos upgrade, i got more than i expected. Share lang, astig eh. Guage 8 pala pinalagay ko.
Toyota Corolla AE101 Owners & Discussions [Merged]
