Results 5,301 to 5,310 of 5477
January 20th, 2020 07:02 PM #5301
January 20th, 2020 09:25 PM #5302
Normally pagkaalam ko kasama sa 35k service na yan brake cleaning and adjustment. So not sure why may separate work pa kailangan para sa brakes.
Fuel injector cleaner is chemical lang naman na hinahalo nila sa fuel tank. Basically similar lang sa Caltex Techron additive. As long as regular mo naman nagagamit sasakyan at hinde ka natutuyuan ng gasolina is not needed yan. Pwede mo na ipatanggal.
If drums yun sa rear is doon lang ang adjustment.
Sa handbrake naman is may adjustment din. Naka base yan sa clicks ng notches pag inaangat mo yun handbrake. Normally mga 5-7 notches yan sa lever type pero depende sa service specs.
Midtronics is a good brand of battery tester/analyzer. Mamahalin pa. Kaya dapat tama ang pag gamit.
Make sure the technicians do a complete check using the tester - this requires the cranking test(starting the car) up to loaded test (AC, full blower and lights on). If may printer unit nila bibigyan ka ng print out galing sa tester.
January 20th, 2020 11:43 PM #5303
Thanks
Thanks. My last PMS was in February 2019 so I'll have the brakes cleaned then
Thanks! I will have the fuel injector cleaner removed.
I do need the midtronics because my battery is about to turn 4 (Amaron)
BTW, I left my car parked for 3 days and when I started it, it seems like the radio was reset. Is that a sign of a battery problem?
January 21st, 2020 12:46 AM #5304
January 21st, 2020 12:58 AM #5305
No, first time it happened I have the battery indicator that I bought in Lazada at it says 13.7, not sure if that's accurate
4 yr battery is kinda sulit na rin, though I just paid for my car insurance and I'm hoping my battery will last one more month
January 21st, 2020 02:20 AM #5306
January 21st, 2020 07:15 AM #5307
may nakita ako (1 case lang naman) ..
melting / sticky dashboard sa Altis club, naka 11th gen
- Jan 2020
- 1
January 23rd, 2020 01:29 AM #5308Meron po ba kayong alam na mapagbibilhan ng Caliper sliding pin for 2016 corolla altis? kung may online mas better po
February 20th, 2020 12:29 AM #5309
- May 2011
- 19
February 21st, 2020 02:05 PM #5310May nakapag try na sa inyo mag open ng waze sa standard touch screen ng 11.5 gen? Not sure if this is possible.
