Results 5,431 to 5,440 of 5464
- Oct 2013
- 2,537
September 7th, 2022 12:42 PM #5432
- 52,517
September 7th, 2022 01:05 PM #5433are you losing coolant?
look at the rubber gasket under the cap, and see if it is perished, i.e., cracked. replacing the cap should solve the problem. be sure the mating surfaces of your cap and your radiator neck, are clean.
another possibility is, your car is overheating and the cap is allowing some coolant to leak thru, as is its design.
is your overflow cannister losing coolant? if so, that's a sign that your engine may be overheating, even as the temperature gauge doesn't show it.
as an aside,
my old non-toyota was overheating and losing coolant.
i tried everything.
finally, it was traced to a weak fan.
replacing the fan with a new unit, solved the issue.Last edited by dr. d; September 7th, 2022 at 01:10 PM.
- Oct 2018
- 18
September 16th, 2022 12:43 PM #5434Thinking of getting an 11th gen 2nd hand Altis
Any pros and cons for this model?
Also, ano ang budget for say 2015 to 2016 na top of the line?
September 16th, 2022 02:09 PM #5435
Radiator caps have ratings ... depending on the pressure they can handle ...16 psi is the norm ...
September 16th, 2022 06:55 PM #5436
September 22nd, 2022 09:14 PM #5437
So I went out today and when I parked my car, sakto 40k 😊
Nobody can accuse me of tampering the odometer of my 2014 Altis, I have receipts - literally (all casa records) and photos
September 23rd, 2022 11:14 AM #5439
October 4th, 2022 11:13 AM #5440
With the advancement in technology such as the internet (now with netflix), DVD's and Cable, it...
Traffic!
