Results 3,031 to 3,040 of 3568
- 52,521
October 15th, 2017 11:54 PM #3031depende naman kung gaano ka-taas ang air pressure sa compressor nila.
kung mataas pressure, mabilis.
kung hindi gaanong mataas pressure, mas matagal ang lagay hangin.
i look at the pressure gauge of the gadget, to see that the correct pressure is delivered.
and it is also a good maneuver to go out and check, because sometimes, they forget to screw back on, the cap covers.
- Jun 2012
- 93
October 16th, 2017 12:02 AM #3032ill look closely ba sa gauge na parang dapat stable siya for how many seconds po usually bago sabihing enough na?
Sent from my HUAWEI MT7-TL10 using Tsikot Forums mobile app
- 52,521
October 16th, 2017 12:06 AM #3033the one i go to, has a digital read-out.
the operator punches in the desired pressure. then he attaches the nozzle to the tire, upon which it will give the opening pressure. then, as air is pushed in, you will see the numbers go up until the desired pressure, after which it pings a sound.
end of filling.Last edited by dr. d; October 16th, 2017 at 12:08 AM.
- Jun 2012
- 93
October 16th, 2017 12:08 AM #3034ok theres a sound naman pala once its ok na...
- 285
October 17th, 2017 05:21 PM #3035
October 18th, 2017 09:19 PM #3036
October 18th, 2017 09:26 PM #3037
Nagpapalit na ako ng gulong kanina sa bridgestone. Nagpromo kasi un ecopia ep200. 195/65/15 at 3,285php (cash) per tire. Pag credit card nasa 3,555php. Problem nung istart na naman un kotse, ayaw mag start. Inabot kami ng 30 mins just to stsrt na car. Parang nag lock un manibela. Ginawa na namin un move left and right sa manibela ayaw parin. In the end, nagstart sya, pero ang problema ngayon, hindi matanggal un susi. Hanggang accessories nalang sya. Hindi mapihiy sa off para mabunot ang susi. Weird thing is un susi ko, isang side lang gumagana. Pag kabilang side ang pinasok mo sa key ignition, hindi pumapasok. Normal ba un? Alam ko kahit anong kotse both sides ng susi maipapasok mo. Since nabili ko un unit last month ganun talaga un susi. Iniwan ko sa talyer ng nakaopen ang driver’s side window kasi baka mag autolock. Dadaan ako ulit para iwan un spare key. check din nila kung ano sira. Baka ignition coil daw.
4 shops na un tinanungan ko at lahat sila rack and pinion ang culprit ng “tok” sound sa manibela. Malaki na gastos ko sa altis na nabili ko.
- 52,521
October 20th, 2017 12:23 AM #3038your suspicion is correct. either side of the key should work. look closely at the key. do both blades look the same?
either the key is worn out, or the keyhole pins are worn out.
although both can be remedied, i'd start with the key, as it is cheaper. ask the key duplicating man to make you a new key. ask him not to follow the old key too faithfully, para medyo mas mataas ang mga ipin ng bagong susi. see if that helps you manipulate the keyhole.Last edited by dr. d; October 20th, 2017 at 12:36 AM.
- Jun 2012
- 93
October 21st, 2017 12:49 AM #3039goodpm,if the oil is parang clear pa din hindi madumi since super bihira magamit ang sasakyan due na kaya siya for change oil,di ko na natanong sa driver when pa last nag change oil wala na akong contact sa driver...
i think 10km a month lang siya gamit.thankyou
- 52,521
October 21st, 2017 12:54 AM #3040
You can add , The Ten Commandments, BenHur ....
Traffic!
