Results 2,511 to 2,520 of 3568
September 4th, 2015 10:54 AM #2511
anyone can have a flat tire while driving.
SLEX naman yun, you could have waited or called (kung may number ka) ng SLEX patrol.
pero since you are at it, better carry around a portable air compressor around.
- Nov 2011
- 68
September 4th, 2015 11:57 AM #2512Thanks sir SkyFlakes88! Will drop-by sa bridgestone alabang today. Hopefully okay pa yun mag.
Yes sir. Pumunta muna ko sa shoulder and double check kung alin gulong nag na flat-an (sa may right-side rear). So when I confirmed na flat nga, iniisip ko na mga options ko and nakita ko mejo tanaw ko na yun shell because of the jollibee logo. So I went there nalang since di din ako marnung mag change ng tire and walang ilaw sa area.
Ahhh. Thanks for the tip. Hindi ko siya naisip before. Ika-nga learn from your mistakes so lesson learned.
Upon inspection today sir, I found a hole sa tire so most likely ito nga yun.
I'll save SLEX patrol number nadin since I don't have it. Btw, may bayad ba yun if ever puntahan ka nila and nag papalit sila ng tire?
Maraming salamat sirs! There is always a "first" talaga sa lahat ng bagay. Lesson learned to bring air compressor.
Mabuhay po kayo.
September 4th, 2015 12:16 PM #2513
I hope your mags survived. There will be chips and dings but i think it is ok. Just might need more lead weights to compensate the small damages when installing a new tire and it's all good to go.
Best is to learn how to change tires so you won't get stuck by the road with a just a flat tire sir.
September 4th, 2015 12:56 PM #2514
nope. walang bayad yung SLEX patrol for this..... ang gagawin lang naman nila is babantayan ka nila habang nagpapalit ka ng tire eh to avoid accidents.
however, kung makatapat ka ng sobrang bait na enforcer dyan baka tulungan ka na nila mag palit o sila na magpalit ng tire mo.
September 4th, 2015 01:14 PM #2515
- Nov 2011
- 68
September 4th, 2015 02:38 PM #2516Kakagaling ko lang ng bridgestone alabang. Quote is 6.4k un tire alone plus un weights 100 weights, alignment 2wheels 800, 1200 4 wheels. Yikess ang mahal pala. Same price lang ba ito sa lahat ng bridgestone branches?
September 4th, 2015 02:50 PM #2517
September 4th, 2015 03:00 PM #2518
^Altis uses 195/65R15 ata. Try also checking on olx. Minsan may mga good deals. Baka makatiming ng OEM 16s.
Check the Toyo and Kumho at S&R.
- Aug 2012
- 346
September 4th, 2015 03:01 PM #2519
- Aug 2015
- 862
September 4th, 2015 05:12 PM #2520Try gomags evangelista makati. Baka maka libre ka pa sa alignment.
