Results 1,501 to 1,510 of 3568
January 27th, 2013 08:10 PM #1501
Nice! Galit sa pera pang mods ah.
Side shot w clearer view of the rims.
January 27th, 2013 09:16 PM #1502
January 28th, 2013 02:53 PM #1503
Hi guys,
May I ask what's the best rims setup for a '09 black 1.6G altis. I need a setup that won't compromise (or at least minimal) FC, ride comfort, etc.. Ito medyo natitipuan ko kasi..
Ok na ba ang 17'' or should I go for 18''? And what are the specs that I need to look for (offset, etc.)
Thanks in advance (btw, yung nasa profile pic ko sana ang ideal setup ko hehe)
January 28th, 2013 04:58 PM #1504
^First and foremost, you have to find rims that come in the 5x100 pattern. That limits your choices usually.
On 17s versus 18s, I'm personally happy with my 215/50R17 set-up but to others, 18s are aesthetically better (along with lowering springs). So for that, it's a matter of your budget and preference. Best to find a lightweight set of rims that will fit so your FC will not be affected; the popular BBS-look Rotas are heavy but if you go for those Volk Copies, they're pretty light AFAIK.
January 28th, 2013 06:26 PM #1505
had out 10th gen (3ZZ-FE) oil change over the weekend. Swak ang 5 incher filter with lots of room to spare pa. A cheap upgrade to the more popular BT223. See image below for reference.
Have a good week ahead folks.
Tsikot Member Rank 3
- Jul 2004
- 1,540
January 29th, 2013 02:01 PM #1506Just an observation when I drove our Altis in SLEX.
Cruising at 100-110kph from Drive I switched it to the Manual mode, Revs went up and according to the indicator it was in 5th gear so I changed
to 7th gear and RPM was around 2300-2400 which was higher when it was in Drive mode. In drive engine speed was aroun 2000rpm only while cruising
from 100-100kph.
January 29th, 2013 02:49 PM #1507
Hehehe... wala pa bang mas hahaba dyan? Yung tipong sasayad yung oil filter sa humps?
CVT right? I guess in manu-mode the program chooses a more aggressive ratio.
On another note, I'm thinking of ditching my 17s for OEM 16s from the V model... hmmm.Last edited by vinj; January 29th, 2013 at 02:51 PM.
January 29th, 2013 03:24 PM #1508
January 29th, 2013 04:24 PM #1510
hehehe! yung B243 pasok pa am sure. wala pa din sayad.
Sinubukas ko nga yung LF3947, masyado malapad. sayang panalo pa naman filtering efficiency nun. pang pick up at everest lang talaga sya pwede
hanga 7th gear pala yung altis 10.5, not bad.
Oh why oh why? not bad naman yung 17s mo ha idol. kita ko na in person pogi naman.
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
