Results 471 to 480 of 3568
- Feb 2011
- 47
April 28th, 2011 04:50 PM #471When you go outside the car and the smart key is with you while engine is "ON" it will beep trice when you close the door, and the hazard signal and "key not detected" will appear on the panel, but if you leave the door open it will not beep. If you put the transmission on NEUTRAL it will beep continuously if you open the door and will stop the beep if you put it to P.
Guys did you experience na minsan di bumubukas yung trunk when you pull the driver side lever? Yung sa akin na-adjust na minsan ganun pa din.
April 28th, 2011 07:32 PM #472
ako rin ganyan yung trunk latch sa loob minsan ayaw gumana. kainis nga yan e... matagal pa naman bago ako mag 5k kms para bumalik sa casa for PMS.
April 29th, 2011 10:13 PM #473
April 29th, 2011 11:52 PM #474
hey looks like we have the same problem, mine has odometer reading of 2000
last 1k PMS i was complaining of rattle sound around driver side akala ko sa may instrumentation yun pala sa may driver side na pillar yng plastic trimming beside the windshield nanggagaling yung sound i still have to have it check but im sure dun galing kc parang maluwag yng plastic trim
April 30th, 2011 08:38 PM #475
kailangan ipatingin na yan. cuz new pa yung car and to think its an altis pa.
- Jan 2011
- 7
May 1st, 2011 03:19 PM #476*ian28 - The trunk may not open when pulling the driver's side latch if you locked the trunk with the key at 3 o clock position. Try to reposition the trunk's key lock to 12 o clock position.
*spencersy - The rattling sound comes from the A pillars which is hollow. Toyota service center will fill that with insulation foam. Inform the service personnel to put the foam on your next visit.
- Feb 2011
- 47
May 2nd, 2011 08:05 PM #477
May 3rd, 2011 06:54 PM #478
Hi to all Altis owners,
Question lang po, ano pinagkaiba ng G at V when it comes to features? Thanks in advance
- Apr 2011
- 37
May 3rd, 2011 08:06 PM #480hirap humanap ng altis 1.6v ngayon.. di pa naglalabas ang planta.. still waiting for a black 1.6v... tapos tinanggal na nila ang 30k discount.. kakalungkot kase inabot ako ng ganito..
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
