Results 81 to 90 of 3568
December 23rd, 2010 09:15 PM #81
* Dekzee: Wow that was impressive! At may pics pa talaga para mas maintindihan! Hehe.. Props to you
May concern nga lang po ako. Pano niyo po sinimulang tanggalin yung rubber lining? Did you use any tool to help you detach it? Medyo natatakot lang akong galawin kasi baka ma-deform o magkamali ako at hindi na siya maibalik nang maayos.
December 23rd, 2010 09:30 PM #82
December 23rd, 2010 09:41 PM #83
no tools, just grab it by your fingers and gently but firmly pull down. pinaka madaling simulang tanggalin dun sa midway between the A and B pillars then work your way towards the sides. careful pa din sir, if it won't budge then don't force it also, avoid kinking or bending the rubber. So far, sa dinaming beses kong tinatanggal tanggal at binalik to, wala pa namang leaks pag umuulan
Ms Cathy, I'm sorry I don't have the solution or even an explanation for the whistling. Wala kasi ako nung whistling e hehehe, so parang walang necessity on my part, but I'll try to research. Sobrang bwisit ko sa mga rattles kaya ci-nareer ko.
December 23rd, 2010 10:48 PM #84
Regarding those noises, may napapansin din ba kayo na mahinang sound sa may bandang muffler. It's a "tok" sound whenever the car passes through uneven roads. Is it because of the muffler dangling? I tried checking the mudguards but they are all intact.
PS, ang hirap din pala ng masyadong tahimik na kotse, dami mong napapansin na tunog e.(sounds circular reasoning though) hehehe
- Apr 2010
- 201
December 25th, 2010 06:35 PM #85paano po ba tanggalin yung rear seat cover?lahat kasi natanggal ko na at naibalik instead dun sa pinakaupuan sa likod...naiaangat ba yun?if yes, how?
December 25th, 2010 08:27 PM #86
December 25th, 2010 09:11 PM #88
December 25th, 2010 09:27 PM #89
The front part is just secured by 2 metal clamps that can be disengaged by pulling upward while also pushing the cushion towards the rear (position yourself squatting facing the rear). The cushion should now be pulled out completely.
Pero, kung hindi mo matanggal despite ma disengage yung clamps sa harap, baka merong bolt in between the seat cushion and the sandalan. you can remove this by an extended socket wrench. try to feel for this bolt by putting your fingers in the crevice between the seat cusion and the back. good luck.
- Apr 2010
- 201
December 25th, 2010 10:29 PM #90
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
