Results 61 to 70 of 83
- Oct 2013
- 172
January 27th, 2015 01:18 AM #61Hi sirs!
May question lang ako. Recently had a work done on my engine. 2.4v 2004. Had my cylinders resurfaced due to low oil pressure. To make it short, after it was done, i had to take it back due to a leak between cylinder head and engine block. I was informed na di daw masyado masikipan yung bolt because the aluminum block is prone to losing threads. Already replaced the gasket twice after that. 2nd replacement had sealant na pero may leak parin. After researching sa net, sakit nga daw ng 2azfe yun and they recommend to use time sert or heli coil. Aside from this procedure and replacing the block, what are my other options?
January 27th, 2015 06:24 AM #62
Id naman na warp? They should torque it correctly. Baka na over torque kaya nasira ang threads?
January 27th, 2015 09:15 AM #63
We had the same problem on our 2005 Camry when it overheated (due to a busted aux fan). The machine shop fixed it by rethreading (or something like that) all the bolt holes to ensure proper torque specs are attained. That was done over two years ago and the car is still reliable as ever.
- Oct 2013
- 172
January 27th, 2015 10:12 AM #64It was rethreaded a couple of times already before the first assembly. Can you recommend me that machine shop, vinj? Mine was done by roque's in marikina but im from qc.
January 27th, 2015 01:08 PM #66
Were all the holes re-threaded? In our case, before we only rethreaded the bad ones and ended up with leaks later on as the supposedly good ones went bad too (lesson learned, better to rethread all in such cases). Speedyfix outsourced it for us as we had no time to do the legwork already. Try inquiring with VW Precision on A. Roces. They did good work on my friend's engine block before (but that was 10 years ago, dunno how they are now).
- Oct 2013
- 172
January 27th, 2015 06:16 PM #67
- Oct 2013
- 172
January 27th, 2015 06:17 PM #68
January 27th, 2015 06:44 PM #69
^Speedyfix is in San Juan. Take note they charge more than the usual "talyers" though. If your mechanic can already take the engine apart then bring it directly to your own chosen machine shop. You may want to check the gaskets that may need replacement also if this has never been done since your engine is apart already (i bought an overhauling kit from Toyorama for our 2.4)
- Oct 2013
- 172
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
