Results 91 to 100 of 14970
- Mar 2005
- 233
August 17th, 2006 12:59 PM #92i frequently visit a malaysian avanza forum and genting highlands is always mentioned as a reference for avanza's power (or lack of). owners swear that they had no problem even if fully loaded. i just don't know if genting highlands is equivalent to baguio.
but one thing is sure, don't expect the avanza to be a rocket.
- Aug 2003
- 9,720
August 17th, 2006 01:16 PM #93to this day di ko maintindihan why toyota(and while we're on the subject, suzuki) didn't fit a diesel engine on the avanze/apv. kahit 1.3/1.6L lang, imho it's still a better choice for people carriers, di ba? baka masyadong mahal na pag diesel engine
August 17th, 2006 03:19 PM #94
Not really. The big premium on diesel cars nowadays versus their gasoline counterparts is for the turbo systems and the ultra-high pressure injectors. (That is, for cars that have both variants)
If you have a non-turbo CRDi Avanza, it wouldn't cost that much more (maybe 10-20k only) than the gasoline Avanza... but it'd be pitifully slow. Expect a non-turbo CRDi 1.3 to have about 60hp or so.
- Aug 2003
- 9,720
August 17th, 2006 03:28 PM #95Not really. The big premium on diesel cars nowadays versus their gasoline counterparts is for the turbo systems and the ultra-high pressure injectors. (That is, for cars that have both variants)
August 17th, 2006 03:56 PM #96
Not really, because diesel vibration from CRDis are less, and the adaptation, I think, is in the engine mounts themselves, already.
That much is true. But it's up to the consumers. The reason CRDis are getting so expensive is the push to make them as flexible and driver-friendly as gasoline engines, thus, high states of tune (for diesels) and high prices.
If the automakers were to seriously consider their target markets, they'd make clean running cheap diesels with relatively lower performance, but great economy. As it is, modern CRDis command such a price premium that you don't see a return on investment for quite a while...
- Feb 2003
- 324
August 17th, 2006 04:33 PM #97may P40K to P50K more kaya ang turbocharged crdi diesel engine over a gas engine?.. para mura, bare model tapos naka diesel...
August 17th, 2006 04:51 PM #98
if you look at the price differential of the Getz 1.4L and the 1.5L turbodiesel, it's quite a lot, 80k-ish or about 15% of the price of the vehicle.
if you compare the Innova J gas and J diesel, which uses a decidedly lower-tech diesel but still a turbodiesel, the difference is less.
i would suspect that the Avanza has a high-revving engine (it is a VVT-i after all) and short gears, so it can handle Genting Highlands. it would not get great fuel economy though, probably 4-5km/L. which is the same economy that FX's get when filled to the brim.
August 17th, 2006 05:12 PM #99
Toyota Avanza is one of the most sellable vehicle in Indonesia. Hope toyota can also give way to Toyota Xaris so it can compete with Honda Jazz.
August 17th, 2006 05:19 PM #100
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
