Results 31 to 35 of 35
September 30th, 2016 09:30 AM #31
- Aug 2016
- 252
September 30th, 2016 10:01 AM #32
- 52,698
September 30th, 2016 11:04 AM #33
- Jul 2016
- 939
September 30th, 2016 11:05 AM #34Ok, medyo technical pero sana may makita ka shop na kaya gawin to.
Lagay kayo pressure gauge tapped on or near fuel rail. On some cars may abang na to tap quick connect fittings, etc...
Key ON, engine OFF. - Dapat around 40psi.
Crank engine engine - Dapat ma maintain ito or mag drop lowest na 35psi.
A workshop manual will help alot sa specs pero generally yan na yun.
Not sure sa altis, pero if bago na pump mo. Baka ung pressure regulator in fuel rail or sa pump casing loose na seals at may leak na.
Try mo rin, mga 3times mo muna key on engine off cycle, para ma prime ung fuel rail, then sa 4th saka mo start agad wag mo na antayin mawala engine light basta start agad.
EDIT: Sama mo na rin battery. Pa jump ka sa friend mo with his engine running para mas malakas kuryente sabay i-test start mo. If 1 click lang, alam na.
- Aug 2016
- 252
September 30th, 2016 03:52 PM #35
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
