Page 146 of 162 FirstFirst ... 4696136142143144145146147148149150156 ... LastLast
Results 1,451 to 1,460 of 1613
    Apr 2011
    #1451
    sa dip stick po ng power steering ano po ang ibig sabihin ng hot at cold....san po ako mag lelevel salamat po na marami
    Jun 2014
    #1452
    Quote Originally Posted by greg2 View Post
    Refers to the temperature of the engine at the time of dip stick measurement. Level power steering fluid based on this.
    How to know if the engine is hot or cold. . .
    Idikit ang dila sa tambutso. (joke lang po)
    May 2015
    #1453
    sir ask lang din po i have a 98 tamaraw Gas 7k engine las pinas area
    1. ang main problem ko lang po is under temperature gauge umaabot sa dulong white ung temp ko lalong lalo na pag tirik araw 12nn tanghali pero hindi umaabot sa red area ok lang po ba ito and with aircon on po ganito siya pero kung aircon off is nasa half lang siya nagbabawas po ng tubig sa radiator lang po konti konti lang ok lang po ba ito?
    2. Pano po maalis ung tagtag sa fx? halos parang bibigay kasi si tamtam pag nasa rough road lalo na po ginagawa dito samin ng maynilad ung area parang mawawasak ung tunog ng fx pag dinadaan ko sa area na yun
    #1454
    Quote Originally Posted by tech27pro View Post
    1. You're on the verge of overheating. Normal operating temp is at the middle of the gauge only. You should first try checking your cooling system: Radiator, radiator cap, radiator fan (silicon charge), thermostat valve, radiator hoses. Then the AC system: Check if your system encounters a high pressure. You may solve this by general cleaning (sometimes includes replacement of drier & expansion valve) or the installation of a auxiliary fan
    2. Matagtag talaga ang FX. Halos lahat ng ladder frame chassis eh ganyan, pero matibay naman. Try reducing your tire pressure to at least 30 psi at the front then 35 at the back. Syanga pala, kahit SUV or anong luxury vehicle, magiging matagtag at may posibilidad na masira pag dumaan sa Maynilad work area. Sabi nga ng pesteng moto nila "konting tiis lang, dadaloy din ang ginhawa". Parang puro tiis na lang yata ang mararanasan sa dinaanan ng hukay nila!
    Jun 2008
    #1455
    Good day mga bossing mayroon kayo referral for overhaul of engine, tia
    Aug 2015
    #1456
    New user here. Minana lang po 96 GL Tamaraw FX. thanks and more power!
    Apr 2014
    #1457
    Quote Originally Posted by jvnj View Post
    Sir, check nyo rin ball joints ng fx nyo baka palitin na. Yan kase karaniwan ang tumutunog kapag may tama na.
    Sir, check nyo rin ball joints ng fx nyo baka palitin na. Yan kase karaniwang tumutunog kapag may tama na.
    Oct 2015
    #1458
    Hello po mga kapatid.. Planning to buy FX diesel or gas.. Ok po ba ung 5k na fx po paahon kasi sa amin any advices po is appreciated..
    Oct 2015
    #1459
    Pa help po mga sir kung ano po maganda.. Hopefully soon I can owe my long time idol FX..
    Jun 2011
    #1460
    Get a diesel sir... You can find nasa 100k price range...
Tamaraw FX Owners
