Results 1,441 to 1,450 of 1613
April 24th, 2015 10:31 PM #1441
April 24th, 2015 10:43 PM #1442
- Apr 2011
- 198
April 25th, 2015 07:57 PM #1443sori po nagkamali ako sa pag address
sir jvnj,
pano po ang pag mix ng concentrated coolant?tnx po
- Oct 2013
- 1,181
- Nov 2008
- 641
April 26th, 2015 11:36 AM #1445+1 on vvti2.0's recommendation. Just make sure you use a well known or trusted brand of coolant. I personally use Prestone premix coolant (not advertising here ), para 100% sure, wala ng halo-halo. Thanks!
- Apr 2015
- 2
April 26th, 2015 11:48 AM #1446May nabasa po ako sa thread na pinalitan ang jet into 95 and 100. May nakagamit na po ba nito? Musta po ang performance?
At may napansin po ako sa Fx namin. Kapag naka idle or naka hinto at nakabukas ang aircon, tumataas po ang temp, mga above normal. Kapag na andar na balik normal. Di namin magamit aircon kapag traffic baka kasi mag overheat. Need your advice. TIA.
- Nov 2008
- 641
April 26th, 2015 12:24 PM #1447I'm not a fan of tweaking what's originally designed. Tweaking is I guess a compromise between better and bad, it may improve or it may worsen the condition. To answer your question, yes, out of curiosity I tried it. But the results were not impressive. I opted to bring it back to original specs.
Regarding your temp, try checking your radiator clutch fan. It may need silicon oil refilling, or worst may need replacement. Also, better have an A/C technician check your Aircon system. Your A/C might be experiencing abnormal high pressure causing more load to your engine, thus the rising of temp. Also, if you still haven't installed one, try installing an auxiliary fan. This will further improve your A/C system.
I hope your thermostat valve is still intact, check this also. Thanks
- Apr 2011
- 198
May 14th, 2015 03:51 PM #1448hello po sir vvti2.0
pano po sa1 galoon of distilled water(4liters)at 1 liter of concentrated coolant
- Oct 2013
- 1,181
May 17th, 2015 04:58 PM #1449Sa 1 gallon of distilled, dapat 1 gallon rin na coolant concentrate. Use the Toyota red, wala ata available na gallon nito, liter lang.
- Apr 2011
- 198
May 19th, 2015 02:55 PM #1450salamat po......mahal pala i liter of concentrated coolant dito sa baguio ay 400x4=1600
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
