Page 144 of 162 FirstFirst ... 4494134140141142143144145146147148154 ... LastLast
Results 1,431 to 1,440 of 1613
    #1431
    2.5K ang siningil sakin some time back.
    ok na siguro yung 1.8K !
    kung kaya ng budget, palitan mo na lahat.. clutch assembly w/ disk, and release bearing.
    +1 on what dr. d has suggested. Much better if you use OEM specs as it will give better performance and will last long than replacement parts.
    Mar 2015
    #1432
    thank you dr.d. natakot naman ako dun sa sabi nyo na "kung kaya ng budget..." kapag pinapalitan ko ba ung mga un around how much will it cost? kasi kakapalit pa lang po namin ng tierod and ball joints.
    #1433
    Quote Originally Posted by Anino78 View Post
    i have no idea how much.. but as it's an older model,it should not be as expensive as an innova's.
    tawag ka sa tindahan.. toyorama.. celica..
    nung tumawag ako, nahimatay ako nang malaman kong 10K ang aabutin ng piyesa ng clutch assembly ng innova ko..
    #1434
    Hindi naman ganun kamahal, in fact nacanvass ko yung parts nyan nung magpapalit ako ng clutch release bearing...
    From Riken Mdsg., Masangkay, Binondo:
    Clutch Disc (Aisin)- 1,2K
    Release Brg. (Koyo)- 650
    Pressure Plate (Aisin)- 1,960
    Labor - 1,500
    HTH
    #1435
    Labor - 1,500
    HTH
    kung for innova diesel, ok yan, a!
    sa toyorama ako tumawag at sa cuenta nila ay 10K daw..
    Mar 2015
    #1436
    thanks mga sir sa reply. Sir Flipo revo gas din po ba ride nyo? Im planning to canvas the parts needed but i dont know what to ask the autoshop. ung mekaniko suggested to wait na maibaba ung transmission and ibibigay nya ung parts para may sample na ipakita sa shops. ung clutch disc, release bearing, pressure plate ng revo dlx isan model lng ba? pwede ko ba itanong lng sa shop ung mga parts na un para sa revo dlx gas? thanks.
    #1437
    FX 2C yung sa akin
    FX 2C yung sa akin
    Aug 2012
    #1438
    Mga sir..
    ano po kaya problema ng transmission ko? bali 5k gasoline converted to 3c po makina ko binalik yung original transmission ng 5k, bagong clutch disk, pressure plate, release bearing, pilot bearing.. pero pag naka idle ako clutch not pressed may rattling sound (parang inaalog na lata na may bearing sa loob ang tunog).. pero nawawala naman pag press ng clutch, so far wala naman po effect sa performance pero irritating yung tunog, ano po kaya problema? thanks
    Mga sir..
    Apr 2015
    #1439
    Hi everyone. This thread is very informative. Ngayon ko lng nalaman na may ganito palng forum. Anyways, gusto ko lng manghingi ng advice about sa gas consumption ng fx namin. Medyo matakaw sa gas eh. Nagpalit na kame ng jet kaso nilagay ng father ko is 100 and 140 for the secondary. Before it was 140 and 140. Any suggestion will be appreciated. Thanks
    May 2009
    #1440
    Quote Originally Posted by althonix View Post
    ang theory ko jan e mas lalong tumakaw sa 100. kase mas kokonti ang papasok na fuel so therefore mas mahina ang hatak. so ang tendency ng driver e iapak pa ang silinyador higit pa sa dating level nito nung 140 pa sya.
    well, marami pang ibang rason gaya ng tire pressures, binding brakes, ignition problem, clutch wear, yadah yadah......
Tamaraw FX Owners
