Results 1,291 to 1,300 of 1613
- Aug 2010
- 34
July 21st, 2014 08:14 PM #1291Bombahin mo yung fuel pump bago mag start. Mas maganda kung 2 kayo, may bumobomba habang iniistrat hanggang sa umandar tuloy pa din ang bomba. Baka kasi may maliit na leak sa linya kaya di umaakyat ang krudo
- Mar 2010
- 2,249
July 23rd, 2014 08:48 AM #1292
July 23rd, 2014 11:32 AM #1293
- Mar 2010
- 2,249
July 24th, 2014 10:44 AM #1294Update:
Nakabili ako ng Suoer SON-10A Automatic Car Battery Charger, dahil laging nauubos yung charge ng battery ko kapag di mai-start within 2 try. Chinarge ko siya using this charger, after ayaw mag start yesterday morning after 2 start (cold and wet morning due to typhoon Henry). After an hour and a half, fully charge na ay nagstart naman at pina-andar ko ng matagal para kumarga and left the battery voltage * 13.41V and remove the terminal connection for observation of the morning start up.
This morning ay nakadalawang try ako at ayaw mag start, parang kulang sa galit yung power ng battery. Chinarge ko ulit and after mafull charge in 30 mins ay pinatagal ko pa ng 2 hours, pagkatapos ay nagstar naman.
I think mahina na itong 2SM Amaron battery ko na less than a year pa lang. Subukan kong ipa warranty sa dealer.
Please, I need comments and suggestions
July 24th, 2014 03:48 PM #1295
Sir, malamang battery problem nga yan. I've been reading your thread and I suspected that battery is the culprit. If your battery is still within its warranty period you better have the same be checked by the battery dealer where you bought it. Have your wiring and voltage regulator be checked also by your dealer, I think its free.
- Aug 2010
- 34
July 24th, 2014 05:00 PM #1296Sa tingin ko di talaga kaya ng 2sm sa diesel lalo pag luma na ang makina. Yung 2sm ko less than 1yr lang din and madali na madiskarga. Nagpalit na ako ng 3sm.
- 52,523
July 24th, 2014 05:39 PM #1297
July 24th, 2014 07:24 PM #1298
Sir 3sm naman yata kasi ang naka design na battery ng tamaraw fx na diesel, 2C and up. Yong nakita ko na fx 2C ay 3sm nakasalpak na battery. hindi ko lang sure kung may convertion na ginawa sa battery compartment kaya saktong sakto yong 3sm na battery sa fx na nakita ko.
July 24th, 2014 07:28 PM #1299
Sir Flippo magkano score sa battery charger at saan mo nabili yan? Gusto ng ganyan e hehehe
- Aug 2010
- 34
July 24th, 2014 08:04 PM #1300Ang orig na battery ng 2c ay 2sm lang. Yung 3sm halos hindi kasya sa compartment. Ginawa ko lang tinanggal ko muna windshield washer reservior para maipwesto yung 3sm then balik ulit windshield washer reservior. Siksikan sila. Mas komportable talaga sa 3sm yung 2c. Dati kasi sa 2sm parang nanghihina talaga battery pag start. Parang nauubusan dahil sa heater.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
