Results 1,161 to 1,170 of 1613
- Sep 2011
- 262
November 14th, 2013 05:39 PM #1161
- Sep 2011
- 262
December 9th, 2013 01:28 PM #1162
- Nov 2008
- 641
December 10th, 2013 10:25 AM #1163Good to hear ok na yung hard starting mo. So its within the pre heat system nga. Magkano damage dun sa timer Sir?
Sa overheating, maraming possible causes yan. Sa cooling system eto yung possible causes: dirty and clogged radiator, defective radiator cap, defective thermostat, loose radiator fan, colapsing radiator hose, defective water pump, or it might also be a leaking cylinder head gasket. Sa A/C naman, possible causes which leads to overheating: High pressure in the system which might have caused due to dirty condenser, poor ventilation of condenser, clogged drier, defective expansion valve, dirty evaporator. Try opening the cooling system thread Sir, madami kang matututunan dun.
- Mar 2010
- 2,257
December 10th, 2013 12:13 PM #1164Good to know na okey na yung hard starting mo! Ano ang naging problema ng timer at paano naka-apekto sa hard starting?
Maski ako matrapik ako wala akong problema sa overheating, at nito lang last month ako gumamit ng radiator coolant...
Try to follow the advice of jvnj!
Pero last week nasira yung AC, ko daming sira compressor repair (palit ng seal, napalitan na ito last 2 yrs. ago at pati shaft 2nd hand), front evaporator coil due to multiple leak, filter drier may leak sa sight glass (original pa ito). Pinakabitan ko na rin ng isang Aux. fan as recommended by the AC tech.
- Nov 2008
- 641
December 10th, 2013 03:31 PM #1165Sir Flipo,
Yung timer, or relay, nagkaganun din dati yung diesel fx ko. Hard starting, dahil wala na palang kuryenteng tumatagos sa relay kaya di gumagana mga heater plugs. That time ginawan ko na lang ng manual / bypass switch kasi sinisingil ba naman ako nung mekaniko ng 800 sa pyesa pa lang
Yung FX gas ko ngayon awa ng Dyos walang overheat kahit summer. Though gusto ko ding palagyan ng Aux Fan para may tulong during traffic at tirik ang araw, pero di ko malagyan dahil masikip na, masyadong dikit na kasi yung grill. Kaya ngayon, pinadagdagan ko na lang ng silicon oil yung radiator fan para solido ang higop ng hangin. BTW, baka pwede mong i-share Sir diskarte ng paglagay ng fan hehehe!
Thanks!
- Sep 2011
- 262
December 10th, 2013 08:38 PM #1166yung timer ng fx ko bro. 600 pesos ang singil saken, pinalitan nya lang ng parang resistor yung likuran ng timer.
abt sa aux fan bro, maganda kung surplus makuha natin, lakas ng buga ng hangin. meron nga sana akong nakita dito sa malapit sa amin (galing sa Nissan na diesel), kaya lang ang problema, ang design nya, imbes na pabuga, pahigop he he he
- Mar 2010
- 2,257
December 11th, 2013 08:36 AM #1167yung timer pala ay yung relay (maaring time delay relay ito), at di nagbibigay ng direct contact kaya wala or not enough power papunta sa heater plugs.
yung aux fan ay para matulungan yung AC compressor ko na madaling makapag-palamig, dahil napalitan na nga ng seal ito 2 yrs ago, although wala namang problema ako sa overheating.
2 fan nga yung recomenda ng ac tech, pero kulang na yung pera ko kaya isa na lang ang ipinakabit ko, at medyo mahirap nga ikabit pero sila sanay na.
*chito
bro thank's sa info and I'll put that in mind...
- Sep 2011
- 262
December 11th, 2013 08:36 PM #1168eto, bro, almost ganyan rin hitsura ng sa fx natin...
This kit has been specially developed for diesel engines that have Glow Plugs but do not have an automatic heating system. The system functions through an Electronic Timer which automatically adjusts the glow duration time. The Timer is controlled by the Sensor which senses the engine temperature. When the Ignition Switch is turned on, the Timer activates the Heavy Duty Solenoid Switch/ Glow Plug Relay connecting the battery and glow plugs. The Indicator Lamp mounted on the dashboard indicates the glow duration after which the starter should be turned ON.
- Mar 2010
- 2,257
- Sep 2011
- 262
December 16th, 2013 08:16 PM #1170any suggestion kung saan ko pwede ipa check yung overheating issue ng fx ko. pag naka aircon lang naman nag ooverheat at pag na trapik. napansin ko rin pag mabagal ang takbo, tumataas talaga ang temp nya. TIA
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
