Results 1,151 to 1,160 of 1613
- Sep 2011
- 262
November 13th, 2013 08:45 PM #1151
- Mar 2010
- 2,257
November 14th, 2013 08:33 AM #1152Mahirap kung tunog lang ang pagbabasehan.
Ipa compression test mo na lang para malaman ang engine condition.
yung mahabang redondo (kailangan mabilis ang ikot at halos pakadyot lang, at ramdam mo ang power), that is assuming na okay ang engine mo.
Ganito ang experience ko ngayon after overhauling my engine with oversize piston ring, using Amaron battery
yung heater glow plug ko was all still ok when it was checked during overhaul for the 1st time after 13 yrs.
- Nov 2008
- 641
November 14th, 2013 10:13 AM #1153OK bro, that means ok ang starter at battery mo. Given the scenario you stated, your pre-heat system might not be working properly, thus you need to hold on to your starter for a longer time to attain the heat/pressure required by your combustion chamber to get your engine going. Next best thing to do is to check the entire pre-heat system as what ive discussed above/before. If i'm right, your pre-heat system fails to do its job during your initial start-ups.
- Sep 2011
- 262
November 14th, 2013 10:19 AM #1154
- Sep 2011
- 262
November 14th, 2013 10:30 AM #1155I've noticed anothr thng kgbe. Ganun p rn 24 hrs p rn na idle ung fx. 1st try mga 10 secs cguro, d ng start, ng antay lng ako ng another min, hinayaan ko lng cyang nk on, i tried starting d engine again, 5 secs ng start cya. Gawin ko ulit ganun mamaya. Antay ako 1 minuto bago cya i start
- Mar 2010
- 2,257
November 14th, 2013 10:56 AM #1156
- Sep 2011
- 262
November 14th, 2013 12:13 PM #1157
- Mar 2010
- 2,257
November 14th, 2013 12:38 PM #1158Yes overhaul talaga at ang gastos ay 12,000 pesos ang total na gastos; 6,000 pesos ang labor out of that amount.
ipa comprssion test mo muna yung engine mo para sigurado na yun nga ang cause.
siguraduhin mo rin na malakas pa ang battery mo (ilang taon na ba ito?) ipa load test mo ito sa mga battery center, to get true condition.
- Sep 2011
- 262
November 14th, 2013 02:47 PM #1159
- Mar 2010
- 2,257
November 14th, 2013 03:47 PM #1160
chinchilla fur vest leatherjacketback
Verifpro - paypal, ebay, banks, crypto, docs and...
