Results 1,141 to 1,150 of 1613
- Sep 2011
- 262
November 10th, 2013 11:42 PM #1141relay or electrical wiring ng glow plug? tried pumping my fuel filter kanina pero di umubra, tagal pa rin ng dorondo bago umandar ang fx ko. ibig sabihin it's not the fuel filter. ang tanong, how impt are the glow plugs in diesel engine?
- Mar 2010
- 2,256
November 11th, 2013 09:47 AM #1142
- Sep 2011
- 262
November 12th, 2013 11:52 PM #1143
- Mar 2010
- 2,256
November 13th, 2013 08:30 AM #1144yes 2C rin ang FX ko, at na-experience ko din yan noon.
nung una sa umaga hirap i-start, at nang lumaon maski tanghali na ayaw pa rin, at sabi ng mechanic ko ay blowby na or loose compression na.
ginawa ay overhaul, for inspection at oversize lang ng piston ring at palit ng thrust bearing washer nung July 2010, at hanggang ngayon okay pa rin.
make sure okay din ang iyung battery, I'm now using Amaron.
- Nov 2008
- 641
November 13th, 2013 10:12 AM #1145Sir Chito,
The symptoms you mentioned above is usually a sign of a poor pre-heat system. BTW, as you mentioned in your text, ok naman lahat ng glow-plugs mo as tested by your mechanic. May I know as to what exact procedure he did when testing your glow plugs? Usually, there are several steps you can do to check if your pre-heat system is working. 1. directly injecting a 12Vdc source to your individual plugs, if it emits a minimal spark, then the plug coil is good, 2. remove the individual plug and inject a 12Vdc source, this time you will have to see the tip of the plug "glow" or heated. Do not overdo the testing though. If it "glows" then it is ok, 3. test the glow plug line source if there is a DC voltage during the pre-heat period. Check also if the pre-heat period last at least 5 to 10 secs.
BTW, one more question, does your engine crank good enough during cold start-ups? Thanks
- Nov 2008
- 641
November 13th, 2013 10:22 AM #1146
- Nov 2008
- 641
November 13th, 2013 10:27 AM #1147
- Sep 2011
- 262
November 13th, 2013 03:00 PM #1148
- Sep 2011
- 262
November 13th, 2013 03:10 PM #1149
- Nov 2008
- 641
November 13th, 2013 06:26 PM #1150I mean mabilis redondo sir. Kung mabilis naman, try checking the pre-heat system as what ive discussed above.
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
