Page 109 of 162 FirstFirst ... 95999105106107108109110111112113119159 ... LastLast
Results 1,081 to 1,090 of 1613
    Sep 2011
    #1081
    Quote Originally Posted by Dongskie View Post
    Cylinder head bolts paps, ginagamitan ng Torque Wrench yun, hindi basta basta higpit lang at may sequence yung paghigpit ng position ng bolts.
    Hindi head gasket yung fault paps, Mechanic's failure to use proper tools yun. Hindi na-torque tighten yung cyl-head bolts kaya nag warp yung head mo.
    Ano na ba ang status ngayon?
    bro, ang question ko. tama kaya yung mechanic fr binan? gumamit sya ng torque wrench, nahihigpitan pa daw nya dun sa ibabaw, kaya ang diagnosis nya, di daw cylinder head gasket ang source ng leak. ala daw diperensya yung cylinder head gasket. kaya oil seals ang pinagawa ko kasi yun ang recommendation nya.
    nung sabado pa ginawa yung oil seals. at this point, di ko pa masabe kung naayos na yung makina kasi di ko pa nalilinis yung mga patse ng oil dun makina, so di ko pa malalaman kung may bago ngang tagas. ala na kasing araw pag dating ko dito haws kaya di ko maasikaso.
    Sep 2011
    #1082
    Quote Originally Posted by jvnj View Post
    Neat dismantling Sir Dongskie!
    pag ganyan na ba hitsura, pwede na palitan yung ilaw sa odometer, temp,?
    Sep 2011
    #1083
    Hope hindi nag warp yung cylinder head nyo sir. Given the scenario, your mechanic at parañaque didn't follow the crucial procedure in tightening the head bolts, which is critical in the engine's stability.
    Hope the re-tightening addressed your leaks
    nag overheat daw (nag overheat naman talaga ako, sa pagkatanda ko siguro mga more than 3 times) kaya nasira cylinder head gasket. so recommendation nya palitan ang cylinder head gasket. kaya bumili ako ng cylinder head gasket fr Toyota. pero di nga natuloy dahil iba naman recommendation nung mechanic from biñan. magulo ba ang kwento ko, bro? he he he sori kung medyo
    Sep 2013
    #1084
    Quote Originally Posted by chito2011 View Post
    Pwede naman paps, pero masikip pa rin ng konti lalo na sa mga malalaking kamay hehe...
    Mas maganda kalasin talaga yung instrument panel para lubusan na ang pag gawa at linis, pininturahan ko rin yung loob ng panel ng white para hindi na alikabukin.
    Sep 2013
    #1085
    Nalito nga ako, hehehe..
    Sir pinaka maganda niyan ay ipa engine wash mo ng mabuti para matanggal lahat ng oil marks.
    From there afterwards makikita mo na kung may leaks pa or wala na.
    Yung pa palit ng lahat ng oil seals ay most prefered sir specially kung top overhaul, hence "OVERHAUL".
    From that point after the overhaul, dapat ay wala ng tatagas na langis
    Di ko lang magets yung chronological events hahaha
    #1086
    Sir Chito,
    I tried back-reading and here's what I understand: (Nagpa-overhaul ka kasi kumakain na ng langis at may leaks, then nung ma overhaul nag overheat naman dahil may mali at may kulang pala sa cooling system, you tried installing an auxiliary fan to address the overheating and it did. After sometime, may moist of oil leak na coming somewhere the cylinder head and front of your engine. You brought your FX at Cargard and then they changed the oil seal and torque tightened the cylinder head bolts due to findings of insufficient tightening.) This is what I understand, please do correct me if im wrong or something's missing.
    Based on the above, I believe that due to the frequent (3 times) overheating, either your cylinder head MIGHT have warped already or your head gasket might have been burned due to the extensive heat of overheating, which of course have caused your engine, the leaks. I hope the re-tightening has already addressed the leaks, and I do also hope that my analysis is wrong.
    Feb 2013
    #1087
    Meron kasi specific na torque ang bawat screw nyan, meron ako manual ng 2C engine. Specified lahat ng torque.
    #1088
    Quote Originally Posted by siopaonatoasted View Post
    Sir pareho tayong 2C engine baka pwedeng makahingi ng kopya ng manual; ferblona*yahoo.com di pa kasi nagreply yung sa grupotamaraw sa request ko
    may konting tulo kasi ng langis yung sa akin sa mga bolt doon sa cylinder head. napalitan kasi ng piston ring ito nung 2009 at di ko nakitang ginamitan ito ng torque wrench nung mekaniko.
    thanks in advance
    Apr 2011
    #1089
    mga paps baguio city here,blowby na rin ang tam.fx ko gl 1995,2ct.ano ang normal na pinapalitan ng mekaniko kapag blowby na at kano ang ibudget.....sa ngaun wala pang langis sa tambutso,may pressure na lumalabas sa breather with konting oil,(may inilagay nga akong OCC eh) pati sa deepstick normal ang hatak at nakakapasa pa ako sa emission test.pati na sa mga nanghuhuli sa daan hehehehe...
    mga paps baka may alam din kau na nagbebenta ng buong panel gauge(km,temp,etc)sira na kc ang km/h ko di ko alam kung puwedeng marepair.kung sakali anong mods ang ginawa nyo para meron kaung active na km/h gauge dito ko kc based ang changed oil ko...maraming salamat sa mga comments
    Feb 2013
    #1090
Tamaraw FX Owners
