Page 100 of 162 FirstFirst ... 509096979899100101102103104110150 ... LastLast
Results 991 to 1,000 of 1613
    Jan 2013
    #991
    mga sir newbie here ! have tamaraw fx 1.8L 7k, matagal ko na po problema ung back fire ng sasakyan.. pina-change oil, tune up, palit spark plug, timing , binaba na rin yung carburator kahit tubo ng tambutso pero hind pa rin magawa.. help naman baka my irerefer po kayo na mechanic specialist s ganito..
    Jan 2013
    #992
    hello good day mga people...
    i have a tamaraw fx GL 7k gasoline and i did some modifications on it. i change the carburator with a suzuki alto and its just fits perfectly of course with some modifications. the reason why i change the carburator was because of fuel consumption, i want to have more mileage because my old fuel consumption was 1 liter will run 5km in city driving and now that i have change the carburator with the suzuki alto the fuel consumption is still the same or maybe there is a little difference of .5 of liter save than before... i wonder what would be the problem since the jet of the suzuki alto is much smaller than that of an fx.... please help
    #993
    your tamaraw is probably at least 50% heavier the alto. that means it needs at least 50% more energy (force) to bring it up to speed.. then we account for the age of the tamaraw engine, making it less efficient design-wise and wear-and-tear-wise...then we add the friction forces of the larger body, larger engine, etc...
    Jan 2013
    #994
    maybe your right, i didnt account on those things but my tamaraw has still good engine eventhough it starts to consume engine oils but overall there is no trouble about it. but what other factors that can cause very low mileage? change oil is up to date, dont have a hard foot on the pedal i change gears in betweeen 1000-2000 rpm.
    #995
    I agree with sir dr. d. If you back-read on this thread, there is actually nothing more you can do to improve your consumption as the FX's with a 7K engine are built as it is. There is really no other way unless you have it installed /convert with an EFI fuel system (as installed in Revo's) or convert your gasoline engine to Diesel (as well as the applicable differential gear).
    Jan 2013
    #996
    pwede ba e salpak yung engine nang revo na naka EFI sa tamaraw fx mga sir?
    #997
    Yes its doable. Though you have to consider the location where to put the computer box which is mostly inside the cabin or under the dash.
    #998
    Mga sirs, baka may naka experience sa inyo sabay umilaw oil and battery warning sa dashboard ng tamaraw fx 1994 2c engine model. Naexperience ko kasi 2 days na siya ganun. Normal level oil ko and check baterry ko ok naman bale hinigpitan ko na din yung poles. Patulong po mga sirs, TIA.....
    Jan 2013
    #999
    Ask ko lang po mga expert newbie po ako ano po b ang pinakamagandang model ng fx para sa inyo.nag babalak kase ako bumili nabalitaan ko po kase na matibay talaga.TIA PO SA MGA MAGBIBIGAY NG TIPS
    Mar 2013
    #1000
    Mga ka FX tanong ko lang kung may alam kayong nag bebenta ng radiator na mura para sa Tamaraw FX Deluxe na 1997 model at headlight housing....
    Thanks....
Tamaraw FX Owners
