Results 11 to 17 of 17
July 4th, 2004 08:06 PM #11
try mo remove yun injectors then start mo. let the fuel flow out. then reinstall. minsan priming the pump is not enough to remove the air in the system.
- Jun 2004
- 103
July 5th, 2004 09:46 AM #12I asked our electrician to check the error codes. We found out that this Prado has the old OBD1 diagnostics. The error codes register as voltage swings of a voltmeter connected to the diagnostic port, not flashes of the check engine light.
But error code 4 ang lumabas - water temp sensor daw according to the table (from the aussie website). Weird. The table of codes is also weird because there is no No. 3 error code.
Afrasay - Wala talagang fuel na lumalabas from the injection pump. We removed one of the fuel pipes to the No. 1 injector and walang fuel na lumalabas.
There is no electricity going to the injection pump solenoid inspite of all the fuses being ok. As of last night the electrician was still chasing the problem. We switched computer boxes (we have two Prado's) and the vehicle still won't run. But the computer box works on the other Prado so it is definitely not the computer box.
- Dec 2002
- 2,335
July 5th, 2004 05:39 PM #13yung main fuse box na check mo na? Yung under the hood? I would be thinking pag naka ON na yung engine prior to cranking that a battery volatage will be applied to the solenoid to open the fuel line. How did you get the error code? you shorted da service line and the check engine started flashing?
- Jun 2004
- 103
July 5th, 2004 07:14 PM #14The vehicle is already running! We re-wired the injection pump solenoid and the throttle plate sensor to by-pass the computer. Talagang can't find the real culprit and short-cut na lang ito. Pero andar na siya.
At first masyadong mausok pero nawala ang usok after a few kilometers. But there is a problem again. We think the turbo does not cut in. Hanggang 70kph lang ang vehicle - sagad na.
We also suspect that the injection pump was re-adjusted (sinakal) by the calibration shop when we complained of smokey exhaust. We'll bring it back to the calibration shop for a re-adjustment. We are hoping that the turbo is not connected to any of the sensors we rewired.
- Jun 2004
- 103
July 5th, 2004 07:29 PM #15Garyq
All the fuse boxes were checked, under the hood, in the kick panels, ok lahat.
The error codes register as voltage swings. You have to connect a voltmeter to the diagnostic ports and observe and count the voltage swings (+5volts). The check engine lamp does not flash - it only lights up continuously.
The wire to the injection pump solenoid does not register any voltage even with the ignition keys on. That is why the solenoid does not open the fuel line. we also checked all the relays and ok naman. Really hard to diagnose which is why we finally decided on the short-cut. malapit nang sumuko ang electrician.
Tsikot Member Rank 4
- Feb 2004
- 1,704
- Nov 2010
- 1
November 15th, 2010 06:04 PM #17
