Results 1 to 7 of 7
- May 2012
- 26
May 12th, 2012 02:53 PM #1good day mga sir newbie po here.. i just want to consult bout the problem of my corolla GLI 95 ... hindi ko po kc alam kung san ung problem nung oto ko.. hirap po kc syang mag start nung una pag mainit n ung makina (medyo baliktad sa usual n pag malamig hirap mag start) .. ok nmn po ung battery, nagkakarga din po ung alternator.. tpos last wik po while driving namatay po sya tpos ayaw n mag start ulit... ok nmn po ung gas ko.. my tinuro po ung isang mekaniko na may jumper ung isang fuse ko po n PINK ung 30 Amperes.. nung pinalitan ko po un nging ok sya.. pero ilang araw po gnun n nmn sya.. pag ayaw po mag start tinatanggal alis ko po ung fuse n un.. nag sstart n sya ulit.. last wik lng po namatay sya in d middle of edsa tpos gnun hirap n nmn po sya mag start.. my redondo nmn po.. electrical po kya un? nttakot n po kc akong ilabas sa edsa bka biglang mamatay ulit.. hingi lng po ako ng advice sa inyo... salamat po..
- Apr 2011
- 66
May 12th, 2012 06:51 PM #2Bring it to a reputable electrician/electrical shop in your area so it can be troubleshooted properly. From what area are you?
May 14th, 2012 07:56 PM #3
try mo ipa diagnose computer box mo, sabi mo 95 gli tsikot mo may ecu na yan, may check engine ba lumalabas? ipacheck mo din alternator mo kung ok ba supply ng electricity. major tune up, palit lahat air/fuel filter, engine oil, spark plugs, pati high tension wire. and by the way, bawal ang txt/sms speak dito bro. baka mapagalitan ka ng mga mods.
- May 2012
- 26
July 24th, 2012 03:23 PM #4
- May 2012
- 26
July 24th, 2012 03:30 PM #5wala naman pong lumalabas na check engine sir, ayos din naman po yung sa alternator, iniisip ko po palitan na yung computer box kasi may repair na raw po, kaso mahal po pala yun. magkano po ba magpa diagnose ng computer box? by the way thank you po for reminding me about sa speak regulations dito.
- Sep 2012
- 1
September 1st, 2012 03:06 PM #6good day po. i'm having the same problem with my 96 corolla except yung sa akin po ay may check engine light (minsan nag0-on. please advise on what to expect (possible problem) before i go to a mechanic para atleast may idea na ko. baka kasi sabihin nya palitan dapat ang wiper motor haha you know what i mean. noob lang po ako. thanks in advance :D
- Sep 2012
- 3
September 4th, 2012 05:02 PM #7
Thank you!
