Results 1 to 10 of 10
- 9
June 9th, 2008 10:39 AM #1hi there,
need your thoughts on shocks problem. mechanic is offering a service- palitan nya daw insides ng shocks, lower cost.
kayaba bnew shocks kit, instead na bili ng bnew shocks, mas makakamura daw ako.
he is not disclosing how much the cost will be that's why im a bit skeptical.
anyone here had experienced this, please share with me if i'd consider this offer.
thanks!
sinnedo
June 9th, 2008 11:31 AM #2
shock is sealed. ano yan gripo para palitan lang ng gasket. Walk away dont ever look back.
Sign of a broken shock, oil dripping from the tube, car too bouncy, feather wheel at kumakalabog kahit kunting pot hole.
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 9th, 2008 12:35 PM #3try going to cruven. they have a branch in angeles. Had my cars shocks repaired in their crame branch a year and a half ago and its still ok. Other tsikoteers have also tried their services.
http://www.cruven.net/
- 9
June 9th, 2008 01:10 PM #4
June 9th, 2008 03:43 PM #5
if you really need to replace shocks, don't go for KYB kayaba. they are stiff. do a search for kyb kayaba here, you will notice maraming tsikoteers nagsasabi na medyo stiff sila.
June 9th, 2008 04:34 PM #6
- 9
June 10th, 2008 10:36 PM #7
June 11th, 2008 12:13 AM #8shock is sealed. ano yan gripo para palitan lang ng gasket.
anyways, yung kyb if stiffer than OEM's pero natural lang naman yun kasi gas type na yung papalit. if you want softer ride na gas pa din, tokico is for you and mas mura pa!!!
to give you an idea...
2000 civic shocks
kyb -- 1550 per pc
tokico -- 1450 per pc.
- Dec 2006
- 32
June 15th, 2008 11:33 AM #9i tried going to cruven angeles city, complain ko kasi is yung likod ng glxi lancer ko bumababa kapag nag lload ako, so sabi nya, convert natin shocks mo into air or nitrogen filled, 2000+ kasama labor. adjustable daw yun. may fittings sya sa side ng shocks, pinakita sakin. ok ba to?
- Dec 2006
- 32
June 15th, 2008 11:33 AM #10i tried going to cruven angeles city, complain ko kasi is yung likod ng glxi lancer ko bumababa kapag nag lload ako, so sabi nya, convert natin shocks mo into air or nitrogen filled, 2000+ kasama labor. adjustable daw yun. may fittings sya sa side ng shocks, pinakita sakin. ok ba to?
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
