Results 11 to 16 of 16
- Jun 2009
- 226
May 17th, 2011 01:21 PM #11i did not actually see where the adjustment was made. but i was told that they replaced some rubber components. 2009 innova is my ride.
have seen an improvement and the ride is leveled now two years since. mine had an 1inch clearance difference between driver side and passenger side.
- Feb 2008
- 577
May 17th, 2011 03:45 PM #12
- Jun 2009
- 226
May 17th, 2011 04:02 PM #13nope. i did not do alignment afterwards. they would not remove your shocks or anything na pangilalim. rubber spacers lang talaga ilalagay. unless there's another reason why it is misaligned.
it should be covered by the warranty. if they tell you it's not, then complain to the CRO.
- Feb 2003
- 618
May 19th, 2011 01:36 PM #14Yung sa akin new toyota innova v. 2 weeks ago ko lang nakuha. Ganun din sinukat ko. Mas lower ng cguro .25 inch yung sa front left side kaysa sa front right side. I think normal lang naman yata ito unless na super halata. Ganun yata design ng innova sa suspension nila.Basta as long as walang ingay yung ilalim pag daan sa lubak then the very small difference would be ok with me
- Feb 2008
- 325
May 21st, 2011 03:40 PM #15hahaha. just noticed this with my 4 month old innova as well. Di naman talaga halata. ayoko muna ipakalikot. mahirap na. medyo nadala na ko sa experiences ko before, lagi akong namu-murphys law. i'll try to fix a very minor thing tapos lalong lumalala
- Feb 2008
- 577
June 28th, 2011 06:50 PM #16Ok, had mine services for 5k and had the ride height inspected.
Toyota plan DID NOT include the loading requirements during the assembly as the SA told me. All assembly was done in such a way that nothing is inside the vehicle including fuel! - st*p*d i know considering that the tank is not balanced (just on the left side).
ALL innova's suffer this ride height problem. In the showroom wherein the gas tank does not contain anything, is level, but not on innova's rolling on the road with gas tanks not empty, moreover the driver's weight.
Toyota plant has released a 10mm spacer that is placed in cabin mount points 2 and 3 LH. In an unladen position, all stock, tires properly inflated, spare tire mounted, gas tank full, the ride height is exactly level on both LH/RH.
The way I see it, this should have been classified as a recall/repair by Toyota Philippines. Ironically, they won't do this stuff unless a customer asks them to do so. If the customer is out of warranty, then he/she will definitely shoulder the expenses given the prevailing situation.
