Results 1 to 5 of 5
- Aug 2009
- 7
August 6th, 2009 08:39 PM #1Mga sir gudpm po, tanong ko lang kung may nakaencounter na sa inyo ng tunog na nagkikiskisang bakal parang turnilyo na d gaano kalakas pero nakakairita pagtagal. Para siyang mahinang tunog ng ring ng lumang telepono. Sa bandang dashboard siya naririnig and lumalabas siya pagmedyo rough yung road pero pag sa aspalto wala naman. Dinala ko na sa Toyota Shaw ang sabi hindi daw sa dahboard kundi sa labas daw yung tunog at hindi naman delikado. Any inputs mga Sir? Sabi sa akin ng service advisor ko obserbahan kung lalakas pa, magagastusan lang daw ako pagpinatgnan ko pa. Ang car ko po pala ay Innova G. Salamat po...
August 9th, 2009 09:53 PM #2
Sorry to say this buy whoever was that SA you spoke with sa Toyota dealer is better off as a janitor. A classic example of a poorly handled case.
We know for a fact that noise you are hearing is not normal. So, it should be addressed accordingly. They (mechanics) are supposedly trained to handle expected and least expected cases such as that. In my own opinion, tinamad lang yung SA na nakausap mo.
Now since your car is on the new side, I would not recommend taht you have it checked in a mosquito shop. Bring it to another (not the same) Toyota dealer and have them "professionally" assess the car and find out what is causing that metal touching sound. They should (as expected) be able to solve that problem.... PROPERLY.
Good luck!
- Jan 2009
- 123
August 11th, 2009 11:12 AM #3rattling noise o iba pang klaseng noise na di related sa engine, karamihan sa mga mekaniko di alam kung paano ayusin. Sasabihan ka lang na natural lang yan, di naman delikado. Innova bago bat may rattling noise na? Sa mga Vios na taxi na nasakyan ko may kalampag sa right side ng front suspension yata palagi ang naririnig ko. Ang sa akin stereo na bumabangga sa center panel ang culprit parang chirping sound pagnalubak ako. ang ginawa ko nilagyan ko ng rubber tape ang part ng stereo na kumikiskis sa center panel at nawala ang iritating na chirping sound.
November 19th, 2015 12:31 PM #4
November 19th, 2015 01:06 PM #5
I had something of the sort when I got my Innova. There's this metallic vibration or resonant "ringing" near the passenger side of the dashboard that comes up only when the engine is started cold (since engines runs a little rough during cold start-ups). This is a Diesel. The rattle disappears as the engine warms up a few minutes later.
I discovered that it was caused by one of the two computer boxes behind the glove box. A portion of their mounting bracket (right side), I discovered, was vibrating against one side of the right computer box. Slightly tugging on the bracket to put some distance between it and the computer box prevented both from touching each other and eliminated the rattle.
It's a minor fix.
