Results 1 to 9 of 9
October 6th, 2010 09:13 PM #1
sir ano po kaya problem ng toyota corona ko 94 model..
para pong palyado
para pong nalulunod
namamatay po ang makina minsan pag tinupak..
pagbinubuhay ko po ang aircon bumababa ang menor..
need ko po help nio mga sir fist time ko lang po kc magka oto..
October 6th, 2010 09:20 PM #2
Toyota Corona 12R carburator type Pa check mo muna carburator mo baka marumi lang . Iyong mga sparkplug mo baka palitin na . Check mo rin distributor rotor , contact point ,high tension wire, Cap at pag ayos na lahat ito Pa check mo engine timing mo ayon sa specification ng makina.
October 7th, 2010 02:50 PM #4
*tanatej
Toyota Corona 2.0 16valve un lang po alam ko kc un po nkasulat sa engine..
* speed unlimited
many thanks sir..
- Jun 2009
- 325
- 52,698
October 8th, 2010 04:51 PM #6ah! the old electromechanical engine with bulletproof iron block.. fond memories. back when most engine adjustments are do-able in the garage..good luck.
October 8th, 2010 05:40 PM #7
due for tune up na. naipon na ang dumi sa loob ng makina.
check na rin ang mga spark plugs, gas at air filters.
- Mar 2004
- 652
October 8th, 2010 11:26 PM #8here's what you do. kung meron kang knacks kahit konti sa pangangalikot, di masyado mahirap gawin ito.
1. tanggalin mo isa-isa ang mga spark plugs mo. Note their condition. Pag basa ang tip, meaning hindi sumusunog ng fuel. Pag maitim, meaning over rich ang air fuel ratio mo. Pag me oily streak, nag le-leak na o blow by na piston rings mo. A good igniting cylinder should have a sparkplug with light brownish color at its tip.
2. Pag-uma-andar ang makina, try removing the spark plug cable from the spark plug one at a time. note the change in engine performance. pag meron, ibig sabihin, functioning ang said cyinder. try to bring the end of the spark plug cable to the grounding and note the strength of the spark. Shopuld be bluish white.
3. Check your hi-tension cables, condition of your distributor cap.
4. Carburettor. Now, this is another story. pero try mo bumili ng carburator cleaner and follow instructions on the container. baka mag improved.
5. Bring your car to the swerti-fied doctors. kahit sa banawe lang marami magagaling na mekaniko dyan kaya lang ingat ka lang pag dating sa presyuhan.
October 10th, 2010 08:30 PM #9
* burjegol
thank you so much sir
* meledson
thanks sir gas filter need to replace.
sa mga nagreply po thanks ng marami..
Latest mileage:
