Results 1 to 7 of 7
- Mar 2011
- 42
May 30th, 2011 09:27 PM #1mga sirs,
may tanong lang ako regarding sa oil leak sorry po newbie lang ako sa kotse
kapag ginagamit ko siya at iappark ko na may tumutulo pero di naman malakas mga 15 mins
tumutulo siya then kapag malamig na ung makina nawawala na ung tagas saka basa ung
ilalalim nang makina.
gusto ko lang marining mga opinion niyo pag dating sa ganitong sitwasyon. btw ung oil
okay pa kulay gold pa salamat po
May 30th, 2011 09:33 PM #2
Nagka-oil leak na ko sa 1996 Corolla ko. Pinalitan ko ang ff :
1. PCV valve
2. Valve seals
3. Valve cover gasket
Tapos ... nakalimutan ko na yung iba. :hysterical: Wala na ata. Yan na yun. Ewan. Sinabay ko na rin pala tune-up ko nung pinagawa ko yan. To make sure.
1k lang gastos ko sa Toyorama. Genuine lahat.
- Jul 2007
- 83
May 31st, 2011 10:05 AM #3Kung tumatagas sa makina, the seals that you need to replace are the ones on the outside.
Possible leaks may come from the following:
1. Valve Cover Gasket.
2. Oil Sump (Oil Pan)
3. Crankshaft, camshaft, and auxilliary/balance shaft seal (kung meron).
Since you said that the oil leaks when you use the car and stops after 15 minutes, I'm guessing malinis yung makina mo kaya tulo kaagan yung oil. Also, when the engine is running, oil is pumped up to the camshafts and valves and flows back down to the sump. Kapag pinatay mo makina mo, meron pang natitirang oil sa itaas. It might take it another 15 minutes hanggang bumaba ulit sa oil sump. Habang bumababa ito, dadaanan niya yung edge ng valve cover at yung edge ng oil sump kung saan meron gasket na maaring natuyo na at marupok na rin. Silipin mo makina mo kung dito sila nanggagaling.
May 31st, 2011 11:13 AM #4
mabilis lang makita kung saan ang leak, punta ka sa talyer para ma-angat nila kotse mo. most probably sa mga seals, gasket lang yan,
- Mar 2011
- 42
June 24th, 2011 01:47 PM #6
- Mar 2011
- 42
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
