Results 31 to 40 of 49
August 4th, 2006 11:02 PM #31
4x4's share the Fortuner bolt pattern.
- Jul 2006
- 4
August 5th, 2006 01:48 AM #32it seems that the transformation of my pick-up into a G 4x4 form is not a practical choice for most tsikoteers, therefore if you have 250k what would you do to make it look rugged enough for other people to think that its an off-roader use and not as the base model of hilux. And if you have an estimated price breakdown would be a great help. thanks
August 5th, 2006 05:46 PM #33Originally Posted by juggernaut
1.) change the stock steel rims into....(you choice fill in the blanks)
2.) Paint the front bumper into body color (for me I'm ok with the stock gray look)
3.) Paint the front grille into body color. Add chrome inserts if desired.
4.) Add chrome shell on side mirrors. (if you desire bling)
3.) Add a chrome-like rear bumper. (Again if you desire bling)
But one thing you can escape is that the unit would always look like a "J" no more what even with extensive cosmetic modificiations, since the color white is often associated with this variant. Higher end variants that I see are usually in grayish brown metallic, silver metallic or black mica.
But for me the picture below still shows the best modification you can do with your J. Other countries like South Africa are lucky enough to have a higher ground clearance "J"-like variant. Maybe someday when you can find surplus parts from wrecked or junked HiLux 4x4s, you can proceed with the body lift and meatier stock toyota tires.
August 7th, 2006 10:00 PM #34
Just keep it clean and looking new. It's a utility model and it has a certain charm about it (just ask me, vinj, or kimpOy, we have a thing for 'utility' models).
Concentrate on functional bits like a bedliner, rear bumper. If Toyota can install it, the OEM third brake lamp and fog lamps are useful additions.
Alloy wheels for a nicer appearance (Innova wheels will keep the Toyota family look while improving appearance).
Don't get too crazy on accessories, too much and you will look 'pampasada'. Too much borloloy will also make your vehicle age prematurely. Madali kasi malaos ang mga accessories unless they are functional items.
Besides, its usually the utility models that actually get used off-road. You don't want to look like a 'poser', do you?
September 3rd, 2006 02:06 PM #35
I recently saw a Hi-Lux "J" with '06 Rav4 wheels and tires. Looks like compatibility is not a problem this time since both being 5 lug nuts. The upgrade made the Hi-Lux look better and ride higher.
September 3rd, 2006 02:13 PM #36
Palit tires and rims lang, tapos pabody color yung ibang parts. Ok na siguro ito.
September 4th, 2006 05:54 PM #37
I saw an imported Hi-lux that looked exactly like the picture above. The Hi-Lux belonged to a UN agency and has diplomatic plates on. The rear pick-up is like of Hi-lux past with large bold TOYOTA emblazoned on the rear cargo door.
What a waste, they should have sold this kind of basic Hi-Lux here as well as with the 3.0li D4-D (even in 4x2 format would be fine).
September 7th, 2006 02:21 PM #38
Ang problema kasi sa 4x2 Toyota Hilux is hinde parehas sa 4x4, tinitipid nila. Dapat yan kahit 4x2 siya dapat same ang holes nya sa 4x4.
Biro mo ang 4x2 is same naman ang body nya sa 4x4. Yung 4x2, ang holes nang mags nya is 5 holes, parang mags pa nang car ang ginamit. Hinde siya match.
Tama suggestions nang iba, palit ka nang mags and bigtires.
September 7th, 2006 03:40 PM #39
sir juggernaut-- i suggest not to alter the suspension ng hi lux mo.. tama mga sinabi ng mga nagpost ng thread d2... maganda nga porma ng hilux mo but compromised naman ride.. the 4x2 hi lux is not patterned after the 4x4 not like the dmax... benta mo nalng iyong hilux and get a dmax 4x2.... hehehehehe....
September 7th, 2006 04:21 PM #40
just saw 3 units of hilux J today. palit lang ng mags n tires. painted the front bumper white. ayos na! porma na at malinis pa tignan. hindi na mukang company car.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
