Results 1,551 to 1,560 of 1628
- Nov 2013
- 14
November 29th, 2013 04:46 PM #1551ok thanks Zdre for your info. Ginamit ko na lang key to close the car, without switching alarm. I'll try disconnecting the negative terminal of the battery and let's see after a month or two. Also inform him that the car should be road tested at least every month....inform you later the effect of the ECU after a month or two while the battery is disconnected. Malayo po kasi house ng friend ko, sa baguio ako, sa sn fernando la union bahay niya.
But before doing these; nalaman ko pala sa thread na ito na after battery disconnection then reconnected (negative side), the ECU will re-set; will these not do any harm in the operation of the engine afterwards ? NEED SOME REPLY please...thanks
- Nov 2012
- 33
December 3rd, 2013 10:17 PM #1552
- Nov 2013
- 14
- Dec 2010
- 8
December 3rd, 2013 11:12 PM #1554Mga sir un fortunner ng father in-law ko mababa daw un idling nya kya namamatay ang makina sa umpisa kya kailangan pa i-accelrate ng ilan segundo pra hndi mamatay makina ngpalit na sya ng fuel filter ganun p din, may adjustment ba ng idling ng fortunner? anu kya possible causes nun at anu remedyo dun? 2006 AT-G D4D model nya. thanks for the reply and suggestions.
- Dec 2010
- 8
December 8th, 2013 11:12 AM #1557
December 8th, 2013 02:46 PM #1558
- Dec 2010
- 8
I would still prefer a hydrogen car
Hydrogen Fuel: a sobering look at where it's...
