Results 1,601 to 1,610 of 1628
August 19th, 2015 01:01 PM #1601
I think that the current Innova has reached the peak of its maturity and most, if not all of the kinks that were discovered in the last 9 years have been corrected.
I also considered waiting for the new 2016 model but decided against it. Usually, there's almost always some problems associated with the first "all-new" models. Couple that with a higher price tag of the upcoming model, I decided to get the current 2.5D A/T Innova G... and just look the other way when the 2016 model comes out. :D
- 52,727
August 19th, 2015 10:33 PM #1602yes, it is still a good product.
but waiting for the new model is a gamble.. sometimes, the outgoing model is prefered by some users over the incoming model..
isa lang naman ang pintas ko sa current innova... the wider turning circle.. our neighborhood has narrow streets..
- Aug 2005
- 183
August 20th, 2015 12:11 AM #1603
- 52,727
November 30th, 2015 02:23 PM #1604i am confused..
are we blaming the fuel or the filters?
if it is the fuel, then why did the problem cease when the filters were replaced?
i have one of the first batches 0f 2005. my filter warning light lighted up early on (water contamination daw). i replaced the filter myself, and it hasn't recurred since.
wow! ancient na pala itong thread na ito..
- Apr 2012
- 3,469
- 52,727
December 21st, 2015 11:24 AM #1606
- Apr 2012
- 3,469
December 21st, 2015 11:36 AM #1607
December 26th, 2015 08:33 AM #1608
Yung 2005 hilux namin 2kd-ftv engine naka limit lang to 2800rpm. Kaya 110kph lang max kahit todo tapak sa accelerator pedal and naka warning light yung check engine. Paki recommend naman ng shop na magaling mag diagnose and repair. Central? Denso? Berima? Or other shops? Thanks sa sasagot
- Dec 2015
- 10
January 14th, 2016 08:53 AM #1609Help mga sir, naka-experience kasi ako na mag loss power at parang napuputol ung supply ng diesel ng innova dsl MT 2006 ko, minsan pag maalog sa daan namamatayan ako, pag naka aircon ako madalas magclog. pag hindi ako nka aircon madalang mag clog. nagpadiagnose ako sa toyota, need daw ibaba ang tank at cleaning, so pinababa ko na ang tank and line cleaning, change fuel filters, change oil narin, nagpalit nrin ako ng SCV pero kasamaang palad ganon parin..
- Dec 2015
- 10
January 19th, 2016 07:27 AM #1610
hindi parin makita ng Toyota ang problema nung innova ko, wala kasi warning light. pinalitan nila ng ECU pero nandun parin ang problema. ask ko lang, may kinalaman kaya ang electrical wiring ? kapag ba biglang nawalan ng kuryente ang diesel engine, mamamatay ang makina? pasensya na po sa tanong, baguhan talaga ko sa mga sasakyan.
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
