Results 1,571 to 1,580 of 1628
- Dec 2013
- 14
December 21st, 2013 03:49 PM #1571Actually Sir, pina scan kuna ito...nabili ko ang innova ko 2nd hand pero noong binili ko sya ok ang hatak ok ang tunog ng makina.....din after one month nag park ako ng naka incline....hindi ko sya mapa start may nagsabi sa akin na pump ko ung fuel pump din un nag start naman sya....cnabi sa akin pump daw un para mawala ang hangin sa fuel pump....din kinabahan ako doon...kasi ayaw ko naman na lagi ako mag pump...so pina check ko sa DENSO Banawe....nalaman ko sir na pang Automatic ung computer box na nakalagay sa Innova ko kaya pala mababa ang minor niya.......meaning mababa pa sa 1, din sabi sa akin ng DENSO dapat nakalagay sayo is pang MANUAL n computer box...nagulat syempre ako......din nagbayad ako ng 1500 para sa scan ng Innova ko....na eencounter ko lang ang hard starting kapag naka incline mga Sir.......din ngaun sir naka incline ung sasakyan ko kahit pump ko ung fuel pump niya ayaw na talaga mag start pero nagamit ko pa sya kahapon.....ung check engine light naman umiilaw sya kapag naka on din kapag nag start naman sya umaandar sya.....sya nga pala mga sir kapag pump ko sya din start ko...din hindi sya mag start lumalambot ung fuel pump ko..... mga sir help naman......hindi parin start ung sasakyan ko..... please mga sir
- Oct 2013
- 1,181
December 21st, 2013 06:58 PM #1572
December 23rd, 2013 01:52 PM #1573
Saw a black Fortuner with plate ZPP xxx this morning. At 30 kph, it was spewing thick black smoke worse than the jeepney that was running beside it.
- Dec 2013
- 14
January 2nd, 2014 03:20 PM #1574
- Dec 2013
- 14
January 2nd, 2014 03:40 PM #1575
- Jan 2014
- 5
January 27th, 2014 09:37 AM #1576The secret of cars longetivity is following scheduled maintenance. Have two fortuner 2.5 2008 and 3.0 2013 but never had any problem for the first with mileage of 100K and that's the reason to buy a second one. Also any early sign of problem like emitting black smoke must be attended earlier. You can see only few old SUV of this type with that black smoke but I think those owner is saving for maintenance.
Sent from my iPad using Tsikot Forums
January 28th, 2014 08:51 PM #1577
I have a friend with a 6 year old V Fort. It has 160K on the odo. But he is in Thailand. He has no problem whatsoever and has already brought the car to Australia. He does the basic maintenance himself and regularly changes the oil at 5K. I consider him an engine expert and he only follows standard maintenance practice.
- Feb 2014
- 1
February 10th, 2014 04:16 PM #1578good day! mga sir tanong ko lang po kung normal lang pag nagbabawas ng coolant. kasi ung innova ko july 2013 ko nakuha tapos nung dec 2013 kalahati nalang. tinawag ko sa SA sabi normal lang daw un pinadagdagan sakin ng distilled water hanggang sa full. tapos ngayon po nasa kalahati nalang uli... pina check ko na po sa casa wala naman daw leak... D4D po engine
February 10th, 2014 04:46 PM #1579
from decemebr 2013 to february 2014 kalahati na agad sir? abdnormal yan.
- 52,731
February 10th, 2014 10:57 PM #1580well, it depends on your driving habits and driving conditions. where do you do your driving, in the desert? heh heh.
but seriously, mine didn't need topping off for at least 2 years... but i seldom get caught in standstill traffic, and i do my driving when the day isn't too hot..
see if your fans are working fine.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
