Results 1,461 to 1,470 of 1628
June 18th, 2013 11:13 PM #1461
- Jan 2013
- 686
June 19th, 2013 02:22 PM #1462sir.. parang wala naman akong nabasang ganun sa manual ng Innova VVTi ko.. kahit dun sa mga luma kong kotse wala din akong na encounter na ganyan..
in fact pagbumabyahe kami ng bicol at isang stop over lang yun.. pag dating sa destination patay agad makina.. so far yung 12 years (98k+ odo) old kong kotse maganda pa naman makina nya at swabe pa takbo..
June 19th, 2013 02:28 PM #1463
June 19th, 2013 03:27 PM #1464
Sa N.A. Na vehicles if you sonetimes notice naka stop na kayo let say sa bahay, then narining niti umandar yung rad fan. Dont turn the engine off yet. Wait for the fan to shut down itself & wait atleast 3 sec to circulate the cold water inside the block. Then turn the engine off.. Yan lang ang timer ng NA..
June 19th, 2013 03:27 PM #1465
Since the toyota fortuner vvti is a belt driven fan.. No need to wait.. Just turn the engine off.
June 19th, 2013 09:15 PM #1466
Cooldown is not only for the turbo but for the engine as a whole. When you do harddriving, the whole engine experiences elevated temperature, not the turbocharger only. A 30 sec to 2 min cooldown period should be enough. I conducted an experiment by taking temp measurements of the exhaust manifold after a normal drive and after a harddrive (hill climb in montalban). In both cars, my innova d4d and a rio 1.4, both had higher temps immediately after the hardriving. Emphasis is given on a turbocharged engine because of the higher potential for damage on the turbocharger without a proper cooldown. Note, the waiting time for the gates to be opened is already part of the cooldown period. In my case, this usually takes anywhere from 30 secs to 10 mins depending on what time I arrive at home.
June 19th, 2013 09:22 PM #1467
OT
how do you know that the turbo is engage when driving car with d4d?
is the turbo already on when you start the engine? or you need to reach a certain speed?
June 19th, 2013 10:48 PM #1468
afaik, in a certain speed yan sir. on what particular speed the turbo would kick-in that i don't know.
June 20th, 2013 10:27 AM #1469
June 20th, 2013 02:57 PM #1470
thanks sir for the clarification. mali pala pagkaintindi ko sa turbo.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
