Page 143 of 163 FirstFirst ... 4393133139140141142143144145146147153 ... LastLast
Results 1,421 to 1,430 of 1628
    Feb 2013
    #1421
    Quote Originally Posted by micainna View Post
    Thanks sir siopaonatoasted.
    Sir do you know any trusted mechanic in qc other than the casa?
    Thanks again.
    Di ako taga manila sir, kung andito ka sa location ko pwede natin I-ECU scan sasakyan mo para macheck natin problema.
    Oct 2011
    #1422
    Quote Originally Posted by siopaonatoasted View Post
    Turbo must be oiled pero kung yung air intake ang may oil, mukhang iba yan.
    ah oo, wag lang ung air intake. sobra na un.
    Sep 2005
    #1423
    Good morning mga sirs. Re-post ko lang dito.
    May mga tanong ako about what happened to my father in law's fortuner.
    1. May thick white smoke na lumalabas pagka start specially in the morning though nawawala after 30 mins or so. Ano kailangan kong patingnan?
    2. May leak sa fuel injector pump, saan ko pwedeng dalhin para ipagawa?
    3. Saan pwede magpagawa ng remote-key? Sira na pati pindutan.
    Salamat!
    Hi regarding sa question no.3 no need pagawa ang remote pinapalitan po iyan meron ako bnew straight from toyota thailand pm me if inyerested mura lang po
    Jan 2008
    #1424
    Quote Originally Posted by mib904 View Post
    Sir Brian,
    Ung 2012 Innova J D4D ko, napansin ko din na nagkaka-oil sa turbo. Pina check ko sa CASA during my 5K PMS. Sabi nila normal lang daw un. Ibalik ko na lang daw sa kanila pag umulit ng ganun.
    Pinunasan nila sa casa para matuyo ung labas pero paguwi ko, tinanggal ko ung intake hose at nakita ko na medyo madami ngang oil sa loob. Pinunasan ko na din. Up to now, ok pa naman takbo ng Innova ko
    normal po yan kasi nga yung crankcase ventilation hose eh naka connect sa intake.. bale ang setup nyan ganito
    air filter box -> intake hose -> crankcase ventilation-> intake hose-> Turbo inlet -> Turbo outlet -> intercooler-> engine intake
    Oct 2011
    #1425
    Sir, sana may photo din para ma visualize namin ung mga iba't ibang parts.
    Feb 2011
    #1426
    my sister innova e automatic bumigay ang turbo niya 70k odometer.toyota dealer say 138k ang damage buti nalang under warranty pa..kalalabas ko lang ng grandia para tuloy natatakot ako,,talaga ba dali masira turbo ng d4d?innova at grandia has the same engine at turbo..
    Oct 2011
    #1427
    Sir baka naman pinapatay agad ang makina after a high speed driving? disgrasya ang turbo kung ganon.....
    Jul 2010
    #1428
    +1 at baka kahit malamig pa ang engine hataw agad ang takbo kasi yan lang naman ang common nagiging sira ng turbo
    Apr 2013
    #1429
    kahit ba yung mga bagong engine ngayon na D4D prone din sa ganyan? pano po ba alagaan ang sasakyan pag D4D makina?
    Feb 2013
    #1430
    Turbo timer, or hayaang mag cooldown ang turbo bago patayin ang engine.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
