Page 140 of 163 FirstFirst ... 4090130136137138139140141142143144150 ... LastLast
Results 1,391 to 1,400 of 1628
    Oct 2011
    #1391
    Quote Originally Posted by imperialv View Post
    To be exact 9,500++ kms palang natatakbo ang kotse..
    ano findings? naayos na ba? hindi ba lemon?
    Feb 2013
    #1392
    Is there a "fuel-water separator" installed in a Fortuner D-4D engines?
    Mar 2011
    #1393
    Quote Originally Posted by Lone Ranger View Post
    Meron, kasama na sa fuel filter housing.
    Oct 2011
    #1394
    yep, may pang pump doon sa taas ng housing that lets you pump water out just in case water gets through.
    Dec 2007
    #1395
    On the innova, as will probably be the case with the fort, the priming pump and fuel filter is in one housing assembly. The priming pump does not allow you to pump water out, it is used to "prime" the fuel system. The assembly performs some sort of separation because of the housing itself, as water is heavier than diesel fuel, it tends to settle below the fuel, you then use the drain plug to let water out, manually. Fuel water separators usually have transparent bowls that let's you visually inspect for water accumulation. In innova, detections comes automatically and you will be notified through the dashboard notification. You then open the drain plug to let water out.
    Oct 2011
    #1396
    Quote Originally Posted by timo07 View Post
    Ah okay sir, so just open the drain plug and water will come out na? no need to pump water out? yan kasi nakasulat sa instruction. I have never tried it though.
    Feb 2013
    #1397
    Hmmm... Mukhang magkakaroon ako ng D4D hehehe... May gusto makipagswap sa VVTI ko, dagdag lang daw ako ng 100k..
    Oct 2011
    #1398
    same year model sir?
    Feb 2013
    #1399
    Oo, same year and model.
    Oct 2011
    #1400
    D4-D won't disappount you sir. Pogi ba dahil may hoodscoop.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
