Results 1,281 to 1,290 of 1628
- May 2012
- 21
June 25th, 2012 08:10 PM #1281after sir ng 100-120 kph n takbo pg bumbgal ang takbo around 20 to 40 kph w/ rpm 1200 to 1700 rpm engine runs rough. loaded sir mga bagahe gling kc ako ng airport pblik ng batangas city. sa ngaun d nmn ulit ngya2ri hopefully wag n nga lit mngyri un. salamat mga bosing s info...
- Oct 2009
- 52
- Apr 2010
- 156
June 30th, 2012 10:19 PM #1283Boss, may d4d din ako (2.5) rough nga yung makina around 1500 rpm (parang truck or jeep hehe), tapos mag iiba around 1600 rpm to 2000 (where the semi-whistling sound can be heard), then iba nanaman ang tunog from 2000 to 2500 rpm (whistle), then iba nanaman pag 2500 pataas. Di naman siya mahina humatak, actually sa 1500 rpm nag uumpisa lumakas yung engine (assuming you have the right gear).
I assume nung nasa 100 to 120 kph ka, nasa 4th or 5th gear ka (most probably 5th). nag downshift ka ba when you hit 40 kph? with that speed dapat nasa 3rd or 4th gear ka. kung hindi, if you try accelerating, mahihirapan talaga makina.Last edited by agentrambo007; June 30th, 2012 at 10:21 PM. Reason: 5th to 4th
- Apr 2010
- 156
June 30th, 2012 10:25 PM #1284
- Apr 2010
- 156
June 30th, 2012 10:28 PM #1285Sa company, 150k up odo. No choking. 3.0 D4D 2007 model. I inspected their SCVs, mahaba.
By the way, they are running on very dirty fuel (galing sa petron, sa bayan ng sta cruz, zambales)for a very long time na. No prob pa naman. No tirik moments, buti na lang kase bundok yung route namin hehe.
- May 2012
- 21
July 2nd, 2012 03:20 AM #1286parang hirap ang makina pg nsa 2nd or 3rd gear s 4th at 5th ala nmn problema. tama lng nmn ang gear ko sa takbo ng makina pero iba talaga ang tunog. na experience ko lit last june 28. pag ka start ko ng umaga mga 5 mins. ko muna pinaandar ang makina ska ko pinatakbo. ganon lit ang ngyari pgdting ng 1200-1700 rpm mga nasa 20-30 kph iba ang ingay ng makina. dpat ide2retso ko n s casa kso pg tagal tagal nagiging normal na lit ang tunog. sa2bhin lng ng tga casa n ala nmn problema.
- Apr 2010
- 156
July 3rd, 2012 02:47 PM #1287
July 3rd, 2012 02:59 PM #1288
- May 2012
- 21
July 4th, 2012 02:30 AM #1289sa ngayon sir ginagawa ko pagka start sa umaga tinatapakan ko muna ang gas pedal up to 2000+ rpm (mga 3 beses) habang naka neutral ganun din bago ko patayin ang makina. plano ko din palitan ang kurudo na gamit ko from Shell V Power Nitro+ to Fuel Save. baka lang may epekto rin ang krudo na gamit ko. pag umulit ang kakaibang tunog, ii insist ko na sa taga casa na i check nila ang makina kahit magtagal dun ng ilang araw. salamat po ng marami sa mga advice...
July 4th, 2012 04:41 AM #1290
^mali naman yang ginagawa niyo sir. When you start the engine, just leave it at the engines normal idle speed.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
