Results 1,211 to 1,220 of 1628
- Sep 2005
- 224
December 7th, 2011 09:17 PM #1211anyone experience sa Toyota Fortuner 2005 3.0 4x4 yun engine medyo may gggrrr....or rough sound bigla lang kahapon wala eh, pag nag idle up.
December 8th, 2011 09:22 AM #1212
Cge, I'll replaced na my fuel filter. What are the steps of changing a fuel filter? ung fuel filter lang ba ang pinapalitan or meron kasama mga rubber gasket, washers, etc. and may valve or fuel pump (disabled) ba na sinasara dito while replacing the fuel filter? TIA.
December 8th, 2011 01:46 PM #1213
I suggest have it done sa casa para makita mo how they do it. They will usually remove flexible hose connection, remove wiring harness connection, then disassemble the whole fuel filter assembly. Unscrew top portion of filter housing then remove filter element. Change with new element (I don't recall seeing any gasket or o-ring, hence my suggestion to have it done initially sa casa before DIY), reassemble then reconnect hoses, wiring harness. Open drain then use priming pump to remove some air in the assembly. Close drain then continue priming the fuel system before starting engine.
December 10th, 2011 10:31 PM #1214
December 12th, 2011 02:04 PM #1215
Yes, sandali lang nila gawin. The filter element costs under Php500. Actually, during the regular PMS I think it will not cost you extra on labor. Kasama na yata sa regular labor cost nila for the PM. Hindi ko matandaan yung details ng PMS ko. Kung separate, hindi ko lang alam kung magkano ang labor. You can inquire sa casa kung yun lang muna ipapagawa mo.
December 12th, 2011 06:43 PM #1216
nagtataka ako bakit hindi sinama sa PMS and nakalagay kasi sa manual na "fuel filter need not change periodically". So, I was thinking na hindi siya tulad ng oil filter na you got to change it regularly. Anyway, I will just inquire it na lang sa casa. Safe ba pag sa labas na lang ako magpapalit ng fuel filter just in case?
December 13th, 2011 01:57 AM #1217
safe naman yun kung sa labas ka papalit brader, bilin mo na lang ung fuel filter sa labas. hehe. sabi sakin every 20K PMS pinapalitan yun. sakin di na, twing 10K PMS palit na ako nung fuel filter. bali sa 25K PMS ko ulit papapalitan kasi pinalitan ko na last 15K PMS ko. sabi sakin ng chief mechanic, eto no.1 source ng D4D problems, dapat palagi malinis fuel filter dahil sobra sa dumi daw diesel natin dito sa pinas. yung sakin di pa ng indicate na may water sa fuel filter pero nakita ko sa casa kung panu baklasin yun, pinakita sakin mismong fuel filter ko, super color yellow na sya (ang dumi talaga) then may water na sya, di pa lang nga umaabot sa level yung indicator kaya di pa nag la-light sa dashboard.
December 13th, 2011 09:12 AM #1218
December 13th, 2011 10:43 AM #1219
December 13th, 2011 10:47 AM #1220
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
