Results 1,191 to 1,200 of 1628
- Apr 2005
- 130
November 25th, 2011 12:15 PM #1191Just bought a Innova dsl AT. Well that was before I read this thread. Talaga ba na resolve na ang mga issues regarding sa D4-D engine? Some say yes, others say prevalent pa din. For my peace of mind. Kung prevalent pa din I'll have to live with it.
- Apr 2005
- 130
November 26th, 2011 01:29 AM #1192To understand the problems that you and many other diesel-engine-vehicle owners encounter, we need to take a quick look at how a diesel-fuel system works.
Like any internal-combustion engine, a diesel engine has a tank, a fuel filter, a fuel pump, and a fuel delivery and metering system. In a gasoline engine, the fuel delivery and metering system can be a carburetor or an injector. In diesel engines, it's the injection pump and injectors.
Fuel is stored in the tank, and it travels to the injection pump and injectors after it passes through the fuel filter. What's critical in prolonging the component life of your engine is the fuel filter. Its job is to catch and prevent contaminants from getting to either the injection pump or the injectors. The contaminants include water, microscopic particles and bacteria, which may clog the fuel system over time.
When any of the components gets clogged, you get poor engine performance because there is no longer sufficient fuel getting to the engine.
On the other hand, when orifices inside the fuel metering system wear down, you are getting much more fuel than required. When that happens, you will see black smoke coming out of your tail pipe.
Either way, you need to get to a diesel center to check the condition of your vehicle's injection pump.
This is what happens during calibration: The line to every injector is checked for pressure and flow-rate capacity. They are calibrated to standard specification as required by the engine manufacturer. Anything that is out of spec is rebuilt, reconditioned, and parts are replaced when necessary.
Unfortunately, injectors are often neglected. Why do they need to be replaced? The answer is simple. They are part of the fuel delivery and metering system, and they are subject to a much harsher operating environment compared to the injection pump. If you are not going to check them for flow rate, volume and spray pattern, and if you don't rebuild them as necessary at the same time you have your injection pump calibrated, you're wasting resources and time, particularly when there's a drivability problem with the vehicle.
Recently, fuel companies have been coming out with diesel fuels claiming to offer better performance while being cleaner and less harmful to the environment. To my understanding, these products have been blended with additives that enhance certain properties of the fuel for the engines to run smoother and cleaner. Do note that if the mechanical aspects of the engine mentioned above aren't in proper working order, then fuel can only do so much.
To minimize clogging and contamination I would use a very good fuel filter, choose where I get my fuel and change the fuel filter at a much shorter interval than required by the vehicle manufacturer. It's cheap insurance against a much more costly fuel system failure.
Hope this helps!
Regards,
Ferman Lao
Technical editor
November 29th, 2011 09:51 PM #1194
November 29th, 2011 10:10 PM #1195
- Jun 2008
- 1,741
November 29th, 2011 10:20 PM #1196mas maiksi ang interval ng fuel filter change ay mas mabuti sa makina kahit anong brand or fuel ang gamit nyan. wag na antayin yang 5K km interval change, valid lang yang kung dumaan sa fuel separator/treatment unit ang fuel bago i-feed sa makina.
November 29th, 2011 10:28 PM #1197
btw, isa lang ba ang fuel filter sa engine? sa gasoline engine wala ng fuel filter diba?
- Apr 2005
- 130
November 30th, 2011 11:29 AM #1198Top ten basic diesel engine maintenance secrets
With the rising cost of gasoline, a lot of drivers are contemplating switching to diesel engines for fuel economy. What is the basic maintenance required for diesel engines?
When you need an engine with steady torque and pulling power without sacrificing fuel economy, diesel engine is the preferred choice. It has a fuel efficiency of roughly 40% more than gas engines and as such, a good source of reliable power. However, the engine is massive and heavy to offset the stress of high compression which makes this engine a bit pricey compared to gasoline engines.
When it comes to maintenance how do diesel engine compare? Shown are some important highlights below.
1.) Unlike the gas engines, diesel engine has no electrical ignition parts like plugs, wires and moving part like distributor rotor which is subject to wear. These parts have a limited life and have to be changed on regular basis. Because of this, this is one chore we don’t have to worry about.
2.) Diesel engines run at higher compression pressure than gasoline engines. Where the highest compression for most high performance gasoline engines is close to 200 psi, diesel runs almost 3 times that pressure. As a consequence, more heat is generated putting extra demands on the engine cooling system. Study shows diesel engines usually fail 50% more on cooling related problems because it cannot stand prolong overheating. This is why the cooling system is a high maintenance issue.
Tips on basic diesel engine maintenance:
Do you notice that when your gas engine overheats, you can stop it and rest the engine for a few minutes? Later you can re-start and the engine will be fine. If similar situation happens with your diesel engine, the engine is almost always damaged beyond repair.
On some diesel engines, the cooling system uses a coolant filter to control the acidity (or ph value) of the coolant. This filter ensures that the cylinder block does not have a build up of corrosive particles inside.
3.) Gaskets on diesel on engines must be monitored closely since they are exposed to extreme operating conditions. If possible, all mounting bolts must be re-torque at regular intervals to prevent leaks especially in the combustion mounting areas. This is also true for coolant hoses which can deteriorate quickly if not secured properly. A lot of this is also caused by engine vibrations which is common on diesel engines. Always replace a leaky gasket as a set. If one starts to leak, the rest is not far behind.
4.) Since diesel engines use a lot of air, greater attention is paid to the engine air filtration. A common practice among truckers is to install a tell tale plastic indicator on the side of the air filter housing. The indicator changes color as soon as the engine filter element becomes dirty. Cooling this air is also critical especially if the engine is turbocharged. On some high end diesel engines they are fitted with after coolers to cool the air from turbo charger.
5.) The oil filter selection is very important on diesel engines because of the bad elements of sulfur residue and carbon created when fuel is not burn completely. The filter used must meet or exceed the OEM filter recommended by the vehicle manufacturer. This will ensure that all corrosive particles are removed from the oil. Using synthetic oil will also help because the additives in the oil will resist premature breakdown.
6.) Since the cooling system is critical on diesel engines, it is important that an early warning system should be in placed. Located in the dash panel, the early warning device must be easily seen and heard. If the engine has already overheated and it was not caught on time, the engine could be damaged. Most trucks have this feature in their dash and must be checked regularly to see if early warning system works.
7.) The fuel system maintenance is handled in various ways. Always keep the fuel tank full to prevent condensation from building inside the tank which can end up in the fuel injectors. This also requires changing the fuel filters as recommended to prevent moisture build up. Some diesel engines use 2 types of fuel filters to control the presence of moisture in the engine. Some fuel tanks are also design with one way breather vents for the moisture to escape. This vent should be checked occasionally if there is a suspicion that it is restricted.
8.) Diesel engine has very little carbon monoxide, a poisonous gas common to gasoline engines. However, it produces a lot of black soot which is the result of incomplete combustion. Most of this is caused by dirty injectors and faulty injection timing that inject too much fuel. To ward this off, glow plugs are use to heat the combustion chamber to assist in burning the fuel. These glow plugs must be checked especially before winter season.
9.) During winter, diesel engines are normally hard to start and the best way to remedy this is to install an electrical heater to the cylinder block. Another way is to install a heater element in series with the heater hose. In extreme cases of hard starting, a starting fluid is sprayed on combustion chamber but use it sparingly to prevent scoring the cylinder walls at higher rpm.
10.) To prevent engine cylinder block scoring, avoid prolong idle of your diesel engines. A very common habit among drivers especially in winter... diesel engines are made to idle for long hours to keep the cab warm. When diesel engines are run longer in cold temperatures, insufficient lubrication to the piston wall is the result which might lead to piston scoring. It is better off shutting it down and having it plugged in to a coolant heater which is a common practice used for gasoline vehicles in Canada.
With the cost of fuel rising with no end in sight, diesel engine is a good alternative to gasoline engines that must be considered. Knowing the basic diesel engine maintenance is essential if you want to save money in vehicle operation and cost.
- Oct 2011
- 293
November 30th, 2011 12:23 PM #1199May article sa TGP about Innova.
Is there really a problem with the Innova's diesel engine? - Motormouth Online | TopGear.com.ph
Affirmative. Aangat nga yun cover sa likod if ilalagay yun OEM rims. Badtrip. Sent from my...
2021 Honda HR-V/Vezel (3rd Gen)
