Results 971 to 980 of 1628
- Feb 2010
- 17
February 4th, 2011 02:39 PM #971Wow shocking list of problems and I've only managed to read through a few pages. I'd question if they really know what they are doing when they are 'troubleshooting' at the dealerships? I know in Australia the dealerships are pretty bad at it so would expect the same here. Whats with the 'Replace CRDI system' on the front page? Dont they look for the real problem. Thats like saying to the doctoir you have a stomach ache and he does a full organ transplant to fix the problem....extreme! Fuel issues are the number one issue anywhere so make sure you are regularly checking fuel (and air) filtration.
February 7th, 2011 02:12 PM #972
- Jun 2006
- 1,139
February 7th, 2011 05:57 PM #973me pinapahigop sila sa chemical sa intake manifold. Halos 1 quart size non, then hi-rev. I've seen them do this at otis. Although di dapat ginagawa ito pag bago pa lang oto mo.
- Nov 2007
- 68
February 8th, 2011 03:51 PM #974
May chemical na ginagamit, it mixes with the fuel and air mixture. I was able to observe the procedure and I'm glad I had it done. I saw the significant quantity of soot removed from the engine..I can't believe my 3 year old Innova has that much soot in the combustion chamber. Although it was revved, it did not reach the red line.
Anyways, since it is being offered by Toyota as part of their PMS (optional) I am confident that it was throughly tested. As for performance of the unit after treatment, there is a noticeable increase in power, lower engine noise and a 10% increase in fuel economy.
Toyota suggests this treatment for cars 3 years old and above, with subsequent yearly treatment thereafter.
Will I do it again, yes.
Will I recommend it, yes.
Will I buy another Toyota, yes.
February 8th, 2011 04:07 PM #975
February 11th, 2011 06:35 PM #976
Hindi siguro sa combustion chamber lahat galing yon, ang surface na maeexpose lang ay yung ibabaw ng piston at cylinder head, kasama na yung mga valves. Most likely ang soot ay nag accumulate sa exhaust manifold, catalytic converter and exhaust pipes kasama na muffler. I need to check yung details ng chemicals siguro before I try it out. Hindi kasi nakalagay sa manual ang decarbonizing.
- Jun 2008
- 265
February 14th, 2011 09:53 PM #977Hi Guys,
Is the Fortuner 4x2 Manual 2.5 Diesel also affected by the D4D choking and hard start problems?
How about the 4x4 3.0 Diel Fortuner? Is it also affected by the D4d choking and hard start problem?
Thanks
- Jan 2008
- 4,726
February 14th, 2011 10:18 PM #978grabe ang toyota up to now denial stage pa din sila.. kawawa yung may mga innova na bumigay ang engine out of warranty.
yung boss ko ganyan din eh may innova sya 2007 model nung december 2010 nag out of warranty tapos eto na sunod sunod na ang problema.. una nag jejerk daw.. so etong si toyota manila bay nag advise na palitan ang clutch disc at diaphragm for a whooping 17k!! o eh di kumita sila.. tapos a few days ayun namatay na yung engine while driving... so eto si toyota manila bay.. advise ulet reset ecu at replace filter.. so ok na ulet kumita na naman sila... so after a few days ayun namatay nang tuluyan.. so eto si toyota manila bay nag advise ulet.. palitan daw yung SCV... kumita na naman for the 3rd time.. galing talaga!!!
ngayon yung aircon naman ang sira...
- Jun 2008
- 1,741
- Aug 2004
- 1,559
February 15th, 2011 12:22 PM #980My brandnew 2010 HiAce Commuter has White Smoke Problems! If you are planning to use this as a commercial or For-Hire vehicle, I would dissuade buyers from doing so. In my experience, Toyota's D4D engines may not be robust enough to adopt to the various diesel fuel condition available in the local market. I was expecting that this problem should not occur at least during the first 3-years of operation since it was a brand new vehicle. Unfortunately, less than a year and just 11t+ Kms on the odometer, this problem has occurred.
Monk-owned R53
