Results 911 to 920 of 1628
- Jun 2006
- 1,139
- Jul 2009
- 3,604
November 14th, 2010 02:30 PM #912double post =/
- Jul 2009
- 3,604
November 14th, 2010 03:28 PM #915
*ginnova, Is the choking problem encountered by your office mate is the same with the reported problems for this vehicle in the previous year? can you please ex-found further...
Being a d4d user, i want to take a look on this seriously because i want to be more pro active on this regard.
TIA
November 14th, 2010 04:13 PM #916
Fortuner Club Philippines tried to contact Toyota about this last year.
After reading through D-4D issues thread in the FCP forums, TJ Manotoc, even did a brief video report on TV to publicize this choking issue but to no avail. (Try to find it in youtube)
Even despite the increased publicity (bec. of Manotoc's video), Toyota never agreed to a countrywide recall or something. Toyota did agree to quietly diagnose, repair, etc.. the defective units of those who from the forums (FCP and tsikot) who complained. (Good luck to those who don't go to forums or not tech savvy).
Toyota Phils. always manages to sweep it under their rug all the time. Even a direct question and answer with Toyota Phil officials in their plant in Laguna only lead to sheepish looks, feigned ignorance (of the issue) and reticent responses.
- Jun 2008
- 46
November 15th, 2010 12:26 PM #917share ko lang, i have an innova 2005 D4d, encountered hard starting problem after 2 years (2007), toyota replaced fuel inlet pipe and o-ring, problem was solved. after 3 years it happened again... tried to contact toyota , they said that it might be the supply pump or suction control valve, the SCV costs arund Php8200. in the end i opted to go somewhere else, i found a repair shop in alabang and what they did was just initialization,wala pang 3mins tapos na...and it cost me around Php500. immediately problem was solved...hopefully yun lang ang prob at di na maulet...
November 19th, 2010 03:44 PM #918
- Jun 2008
- 46
November 20th, 2010 12:50 PM #919actually sir di ko din alam ano yung "initialization", pag kakasabi sakin nung gumagawa parang sini-synchronize daw ung ecu at supply pump. baka parang reset...anyway meron lang sila ginagamit na scanner, hand-held equipment lang na sinasaksak sa port sa bandang baba ng manibela, then may selection lang na ginagawa...nagpagawa ako sa goodyear...
November 22nd, 2010 07:16 PM #920
could be a bit of chamba and/or to even to cross your fingers tight upon getting your car/d4d vehicle.....
yet I still believe on proper maintenance on the owner of the car; its not just mere sense of the PMS in itself but the best contributor for a diesel engine is on how you perform your driving on the d4d.....
