Page 85 of 163 FirstFirst ... 357581828384858687888995135 ... LastLast
Results 841 to 850 of 1628
    May 2010
    #841
    nabasa mo na lahat siguro ang dapat mong malaman.. and after reading.. make a choice.. its your money anyway...
    for me mag adventure or crosswind ka na lang all power pa compared sa bare j model with a not so trusty d4d engine
    That's right. but i prefer the Adcenture rather than the crosswind. or just by adding a little bit, you can get a SUV which is a 2nd FORD EVEREST .
    hope this helps.
    Sep 2010
    #842
    Hi All,
    I'm planning to buy the 2010 rav4 4w2. Any problems or concern with this suv? thanks
    #843
    VVTi naman yang RAV4 so its fine...
    Sep 2010
    #844
    thanks tidus for the info.
    btw anong pede mong ma advice sken between santa fe and rav4?
    nalilito kac ako kung anong bibilhin.
    #845
    Quote Originally Posted by jolobots View Post
    Off Topic. :doh: :headache:
    Feb 2010
    #846
    Quote Originally Posted by rover2027 View Post
    sir maybe your clutch is slipping,try the clutch tests put gear in fifth and observe if engine dies ok pa clutch mo and if not slipping na clutch mo.ung oil leak if its coming from the hose it maybe blowby oil papunta ng turbo charger to exhaust it outside.try cleaning ang checks hose connections.if it persist a repair or replacement is needed.
    kung mahina na hatak, malamang manipis na clutch disc nyan, pa-check mo na transmission mo at baka pati flywheel madali.
    Feb 2010
    #847
    Quote Originally Posted by Jie11 View Post
    magandang gabi po! i've been following this thread and did observe that sir dieseldude was been a great help to most.
    sir pahelp din po. mausok po yung fortuner V ko pagkapaandar ku sa umaga, then maalog yung makina for a few seconds then maging ok na po cya. I had may change oil with petron trekker the other day but its still the same, no improvement. nagkaganito lang po mula nung nagkrudo aku sa province.
    I suspect the diesel which i used in the province at a petron station where they directed me on the line for the jeepneys., naubos po kasi yung no discount lane nung gasolinahan. nagfull tank ako at d pa po nauubos.
    anu po kaya maganda gawin ku, Thanks a lot
    ipa-check mo injector baka madumi na.
    Oct 2009
    #848
    Santa fe...
    Aug 2010
    #849
    Quote Originally Posted by Dieseldude View Post
    This is probably a supply pump problem which can easily be fixed.
    Pina diagnosed ko last couple of weeks and they said that it's the Suction valve. Need to replace it, common problem because of the dirty diesel in the Philippines is that possible?
    Sep 2008
    #850
    Quote Originally Posted by ocean explorer View Post
    thank you sir ocean explorer, my fort does not have that smoke already upon starting the engine since yesterday. God Bless po!!!
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
