Results 831 to 840 of 1628
- Aug 2008
- 164
September 7th, 2010 11:43 AM #831Good day Bro,
Ask ko lang what are the symptoms na observed mo sa unit mo, did you experience poor or rough idling sa engine or immediately engine stalling before they replaced your SCV. Mine kasi is as per toyota technician suggestion papalitan din daw SCV ng unit ko because after they road test it medyo poor idling at low power daw and this could lead later on on engine stalling kaya nagorder na sila ng SCV sa planta, kaya i'm waiting na lang for the supply to arrive. kamustahin ko din after they replaced your SCV ok na ba unit mo, sana nga this solved the problem before warranty ends. thanks
- Sep 2010
- 53
September 7th, 2010 01:03 PM #832
sir maybe your clutch is slipping,try the clutch tests put gear in fifth and observe if engine dies ok pa clutch mo and if not slipping na clutch mo.ung oil leak if its coming from the hose it maybe blowby oil papunta ng turbo charger to exhaust it outside.try cleaning ang checks hose connections.if it persist a repair or replacement is needed.
September 7th, 2010 01:37 PM #833
The stalling would occur only during stop and go traffic. It would start with rough idling, then after a few minutes the engine would stall. After restarting, the engine would go back to normal.
Since Toyota replaced my SCV two weeks ago, I haven't experienced the problem anymore (cross my fingers).
By the way, there are two model numbers for the SCV, 04226-0L020 and 04226-0L010. The latter one, which was the one used in my unit, is an inch shorter. There's an interesting discussion on this at the Fortuner club forum.
Here's the link: http://pinoyfortuner.14.forumer.com/...pic.php?t=4729
- Sep 2008
- 142
September 7th, 2010 07:59 PM #834magandang gabi po! i've been following this thread and did observe that sir dieseldude was been a great help to most.
sir pahelp din po. mausok po yung fortuner V ko pagkapaandar ku sa umaga, then maalog yung makina for a few seconds then maging ok na po cya. I had may change oil with petron trekker the other day but its still the same, no improvement. nagkaganito lang po mula nung nagkrudo aku sa province.
I suspect the diesel which i used in the province at a petron station where they directed me on the line for the jeepneys., naubos po kasi yung no discount lane nung gasolinahan. nagfull tank ako at d pa po nauubos.
anu po kaya maganda gawin ku, Thanks a lot
- Aug 2008
- 164
September 8th, 2010 10:29 AM #835So bro, what they installed in your unit is the SCV, 04226-0L020 which is the new one, ask ko lang what year model ang innova mo? mine i bought it nov 2007. Ngayon while waiting for the call of toyota for my SCV, naobserved ko lang in my unit na okey naman ang idling at takbo ng unit ko, i do remember sabi ng SA to me na nireprogram din nila ECU ko, do you think reprograming lang ang kailangan sa unit ko, pero as he said my findings din daw sila sa SCV na for replacement din before stalling occurs to me kaya i followed na din their advise.
September 8th, 2010 08:43 PM #836
September 8th, 2010 09:13 PM #837
- Sep 2010
- 3
September 11th, 2010 11:04 PM #838hello po sa lahat. a new member po. HELP naman po pls.
we are planning to buy a second hand Innova D4-D 2008 "J" with 30K mileage. worth it pa po ba to buy, since all the threads I read are all choking, stalling problems? Kindly helps us to decide because huge bucks will be spent. Plus, good investment pa po ba ito to keep? we will be using the car for family use. thanks po...
More power po sa lahat ng Innova owners and users!!!
September 11th, 2010 11:25 PM #839
You have to assess it thoroughly. Is it casa maintained? Do they have records/receipts to show for it?
As for the problems, you can tell detect this easily with a cold engine. It would have a hard time starting, and needing lots of gas pedal throttling in the process. Choking is another thing bec. it usually happens anytime the vehicle is being used on the road. As for the black smoke, try driving normally (no hard revving) and see if any signs of smoke (gray or black) comes out (there should be none) through the exhaust tip.
- Jan 2008
- 4,726
September 11th, 2010 11:28 PM #840
Daming issue ng SU7:grin:
Xiaomi E-Car
