Results 481 to 490 of 1628
- Feb 2004
- 138
January 3rd, 2010 07:29 AM #481Hi tsikoteers,
Im planning to buy an diesel Innova M/T. Aside from the clogged fuel filters, from experience, what are the other possible failures? TIA.
January 3rd, 2010 10:24 AM #483
This might be true because the Sta Fe has. Its just located much lower and at the side.
The problem with 4JA1 is hard starting once compression deteriorates, higher compression=higher temperature of compressed air which facilitates combustion once fuel is sprayed. There are no GP to heat the air.
- May 2009
- 37
January 5th, 2010 06:18 PM #484Sir xfreemanx. If you have a little bigger budget, try to look at the ford everest. I think its a better buy than the innova. Its very true that innovas aree hard to beat when it comes to practicality and of course budget. However, for those who experienced D4D woes..definitely they regret buying the innova. I own an innova J diesel variant. Got it last april. I got it because of limited budget. kung may bigger budget lang ako that time, naka everest ako now. I hope this input help you in your decision.
- Jun 2007
- 207
January 9th, 2010 02:58 PM #485in my opinion,,d4d has yet to prove its durability,if you would buy one,make sure you will dispose it after 3 yrs,vehicles today are not the same as before,they are not anymore that tough,they did it so the casa will make money,and its their marketing strategy,,compare the vehicles before and now,,those old vehicle will probably outlive todays vehicles..i bought a fortuner,but becuase of problems arising,,,i find it hard to maintain and sold and got myself an lc80 instead,,its slower and not so high tech but it will probably outlive the d4d powered fort..toyota cant even replace my fuel supply pump until now,,just becuase they are not the ones who change its oil regularly,,i told them it has nothing to do with their faulty supply pump,,but we had to accept it,,todays car are created with hidden defects so owners will frequent the casa.....so they can robbed the owners .
January 9th, 2010 05:20 PM #486
Quite a conspiracy theory you got there, but I always like conspiracy theories once in a while...
- May 2005
- 215
January 9th, 2010 05:29 PM #487tanong lang po sa mga naka experience na ng ganito. my innova is 5 yrs old, naka 85t na siya. for the past 10t kms i noticed hindi na siya kasing responsive compared to when it was still brand new. alam ko hindi ito hula hula lang kasi na fefeel ko talaga ayaw humataw at walang torque, hindi nga maka akyat ng parking lot kung walang bwelo, e dati kahit mag dead stop ako sa gitna ng paahon, kaya pa rin niyang umakyat. i brought it to toyota manila bay, pero for the past 2 checkups, wala daw silang mahanap, pinalitan na ang EGR(?) at air filter, pero ganun pa rin, accdng to their electronic diagnosis, ok daw, pero i know there is something wrong with it. i used to be able to reach 120kph no sweat, ngayon hirap na hirap mag 120kph, bakit kaya? ano kaya problem at saan ko pwedeng dalhin? thank you po.
- Nov 2009
- 23
January 9th, 2010 05:47 PM #488Is your Innova manual or matic? If its not in the engine... it could be in the tranny... ang problem.
January 11th, 2010 05:38 PM #489
I would assume the fuel filter is replaced regularly and so is not among the possible causes. Mikelsy might be correct that your transmission might be the cause. If M/T, the disc, pressure plates and release bearings might be up for replacement already. One Innova owner, meanwhile, who posted in this thread, or in the Diesel Fuel Injection System Help Desk thread, had the same issue of loosing engine power and it was later attributed to a botched exhaust system job.
January 11th, 2010 07:16 PM #490
try mong pakingan kung may squeking sound while trekking, pag meron ka nadinig baka po sa clutch na yan, nadulas na yung clutch. needs replacement...
Maraming Salamat :)
